As the title says, I’m unable to view quote or invoice PDFs all of a sudden. The error message says “403: Forbidden, Invalid token” Anyone else having similar issues?
Currently on v5.7.49-M125 - self-hosted in docker
It may help to logout and then back in but this could also be a bug.
@david does v5.7.49 require a token to view invoices?
Hi, thanks for the suggestion. I logged out and back in but unfortunately it didn’t solve the issue.
Edit: the PDF does generate on screen if “Show PDF Preview” is enabled in Device Settings, but I can’t save it or view it as it comes up with the above error.
Edit2: I can view the PDF in Safari but not in the Invoice Ninja app (macOS)
Yes that is right, I believe I was seeing the AP forward the API token, perhaps this was web only and not desktop/mobile?
Yup, that is correct
Do the desktop and mobile apps need updating to get rid of the error message? I will use the web apps in the meantime as a workaround.
If you update to the latest version of the web app it should fix the problem.
Yes, I’m using a Safari/Chrome web app in the meantime, until the native desktop & mobile apps are fixed.
Updating to v5.7.51 should fix this
Awesome, thanks for the heads up. Looking forward to seeing the docker image soon.
