Hi folks,
I cannot use the field $publicNotes in my custom design, because the creation of the PDF fails if there is an newline in the “public_notes” field. Do you think this is a bug I should report or am I wrong?
The error message says:
The specified value "!" does not conform to the required format. The format is "#rrggbb" where rr, gg, bb are two-digit hexadecimal numbers."
(Of course I double checked that there is no error in my color formats).
Directly after that error another error occurs which I guess is “the real one”:
edit:1 Uncaught SyntaxError: Unexpected token
in JSON at position 9575
When I click on the message in the debug console of chrome it shows my pre-parsed JSON for pdfmake, and moans the line break in the public_notes field.
Any ideas how I can fix this? The weird thing is that I can use the variable $notesAndTerms without any problems even with line breaks… :-/
Cheers,
Marco
