Yes, I know. I tried to update to it! Yet, it still doesn’t fix the updating problems via Softaculous. As a result, here is the error log you requested:
[2017-09-20 00:04:24] production.ERROR: Illuminate\Database\QueryException [42000] : /home/thc/public_html/inv/vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 729] => SQLSTATE[42000]: Syntax error or access violation: 1067 Invalid default value for ‘qty’ (SQL: ALTER TABLE products CHANGE cost cost NUMERIC(15, 4) NOT NULL, CHANGE qty qty NUMERIC(15, 4) DEFAULT ‘NULL’) {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“url”:“https://tinyhousechattanooga.com/inv/public/update",“previous”:“https://tinyhousechattanooga.com/inv/public”,“user_agent”:“Softaculous”,“ip”:“208.123.117.2”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:"mysql”} []
[2017-11-10 19:51:20] production.ERROR: Symfony\Component\Process\Exception\RuntimeException [0] : /home/thc/public_html/inv/vendor/symfony/process/Process.php [Line 144] => The Process class relies on proc_open, which is not available on your PHP installation. {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“url”:“https://tinyhousechattanooga.com/inv/public/update",“previous”:“https://tinyhousechattanooga.com/inv/public”,“user_agent”:“Softaculous”,“ip”:“208.123.117.2”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:"mysql”} []
[2018-02-06 15:27:07] production.ERROR: Illuminate\Database\QueryException [42000] : /home/thc/public_html/inv/vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 770] => SQLSTATE[42000]: Syntax error or access violation: 1067 Invalid default value for ‘qty’ (SQL: ALTER TABLE products CHANGE cost cost NUMERIC(15, 4) NOT NULL, CHANGE qty qty NUMERIC(15, 4) DEFAULT ‘NULL’) {“context”:“PHP”,“user_id”:0,“account_id”:0,“user_name”:"",“method”:“GET”,“url”:“https://tinyhousechattanooga.com/inv/public/update",“previous”:“https://tinyhousechattanooga.com/inv/public”,“user_agent”:“Softaculous”,“ip”:“208.123.117.2”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:"mysql”} []
[2018-02-06 15:27:44] production.ERROR: Illuminate\Database\QueryException [42S22] : /home/thc/public_html/inv/vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 770] => SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘invoices.partial_due_date’ in ‘field list’ (SQL: select coalesce(invoices.partial_due_date, invoices.due_date) due_date, invoices.balance, invoices.public_id, invoices.invoice_number, clients.name as client_name, contacts.email, contacts.first_name, contacts.last_name, clients.currency_id, clients.public_id as client_public_id, clients.user_id as client_user_id, invoice_type_id from invoices left join clients on clients.id = invoices.client_id left join contacts on contacts.client_id = clients.id where invoices.account_id = 1 and clients.deleted_at is null and contacts.deleted_at is null and invoices.is_recurring = 0 and invoices.quote_invoice_id is null and invoices.balance > 0 and invoices.is_deleted = 0 and invoices.deleted_at is null and invoices.is_public = 1 and contacts.is_primary = 1 and coalesce(invoices.partial_due_date, invoices.due_date) < 2018-02-06 order by invoices.due_date asc limit 50) {“context”:“PHP”,“user_id”:1,“account_id”:1,“user_name”:“Kelley Chambers”,“method”:“GET”,“url”:“https://tinyhousechattanooga.com/inv/public/dashboard",“previous”:“https://tinyhousechattanooga.com/inv/public/login”,“user_agent”:"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_3) AppleWebKit/604.5.6 (KHTML, like Gecko) Version/11.0.3 Safari/604.5.6”,“ip”:“23.118.133.236”,“count”:1,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”} []
[2018-02-06 15:27:55] production.ERROR: Illuminate\Database\QueryException [42S22] : /home/thc/public_html/inv/vendor/laravel/framework/src/Illuminate/Database/Connection.php [Line 770] => SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘invoices.partial_due_date’ in ‘field list’ (SQL: select coalesce(invoices.partial_due_date, invoices.due_date) due_date, invoices.balance, invoices.public_id, invoices.invoice_number, clients.name as client_name, contacts.email, contacts.first_name, contacts.last_name, clients.currency_id, clients.public_id as client_public_id, clients.user_id as client_user_id, invoice_type_id from invoices left join clients on clients.id = invoices.client_id left join contacts on contacts.client_id = clients.id where invoices.account_id = 1 and clients.deleted_at is null and contacts.deleted_at is null and invoices.is_recurring = 0 and invoices.quote_invoice_id is null and invoices.balance > 0 and invoices.is_deleted = 0 and invoices.deleted_at is null and invoices.is_public = 1 and contacts.is_primary = 1 and coalesce(invoices.partial_due_date, invoices.due_date) < 2018-02-06 order by invoices.due_date asc limit 50) {“context”:“PHP”,“user_id”:1,“account_id”:1,“user_name”:“Kelley Chambers”,“method”:“GET”,“url”:“https://tinyhousechattanooga.com/inv/public/dashboard",“previous”:“https://tinyhousechattanooga.com:2083/cpsess4489697603/frontend/paper_lantern/softaculous/index.live.php?act=upgrade&insid=491_61979”,“user_agent”:"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_3) AppleWebKit/604.5.6 (KHTML, like Gecko) Version/11.0.3 Safari/604.5.6”,“ip”:“23.118.133.236”,“count”:2,“is_console”:“no”,“is_api”:“no”,“db_server”:“mysql”} []
