Can't see tax lines in invoice
Version <v5.10.62>
Environment Zip - Self-Hosted
Hi, i recently went from a no tax invoices to two tax rates.
The tax settings are all good.
But when I create a new invoice, on the PDF page it doesn’t appear.
Although the calculations are ok, I can’t see the two tax lines.
It is a custom design, but if I add let’s say subtotal in “settings → invoice design → Total fields” I can see it in the invoice.
Whatever I do I can’t see the two tax lines in the invoice.
Is the tax column included on Settings > Invoice Design > Product Columns?
In my Settings > Invoice Design > Product Columns, I can see that the tax is there.
If you can post screenshots of the edit invoice screen and a sample PDF it may help
Here is when I created an invoice.
And the PDF
Thanks, what’s configured on Settings > Invoice Design > Total Fields
This is what I have inside, Settings > Invoice Design > Total Fields
I believe you want “Total taxes” not “Line taxes” since you aren’t using line item taxes.
But I do need them. Let’s say the price is 100$.
I’m trying to show the following on the invoice:
QST: $9.97
GST: $5.00
Total: $114.97
What do you see with “Total taxes” included?
That’s it, it worked. :blush:
Thanks a lot.
