Working directory: /srv/http/Gestao/InvoiceNinja_v5
Output:
Error Output:
sh: line 1: /srv/http/Gestao/InvoiceNinja_v5/vendor/beganovich/snappdf/versions/1040184-Linux_x64/chrome-linux/chrome: cannot execute binary file: Exec format erro
r
sh: line 1: /srv/http/Gestao/InvoiceNinja_v5/vendor/beganovich/snappdf/versions/1040184-Linux_x64/chrome-linux/chrome: Success
The issue would be you need to run chmod +x on the chrome binary which is something the download function does, if you add --force to the download does it fix the issue for you?
@david
sorry for delay, yes i allways forget im in raspberry…arm system…
i install in my arch linux and everting is normal… i think is the ld-linux-x86-64.so.2 is missing in my pi…i dont know if i can solve…
any suggestion?? is possibel run snappdf in my pi?
@david it is ok, i will try find elp directly with snanpdf…
but now i have new problem, for a will the hosted_ninja take 1 or 2 minutos…my logo not appear… and now
504: Gateway Timeout
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>504 Gateway Timeout</title>
</head><body>
<h1>Gateway Timeout</h1>
<p>The gateway did not receive a timely response
from the upstream server or application.</p>
</body></html>
this error 504 i think i solved by add my domain to hosts file.
hosted_ninja and phantom is work fine…but shappdf if i try to see 1 invoice says failed to load pdf, if i go to costumiza design of pdf show 500 error and if i try to open invoice in windows app show me Cannot raster a malformed pdf file
@david@hillel i just found out, when i go to design i have error 500 and after if i enable the html mode the preview is work fine…
strange?? i realy dont know
