mangaan
1
This morning I want to create new invoices, but ninja won’t let me login anymore (These credentials do not match our records) :((
I use a local server and the last version 2.4.6
try another browser same problem the password is cached in the browser so that can’t be wrong
help!!!
any hints?
Try using /forgot to reset your password.
mangaan
3
You are right it is the same as the ‘Forgot your password?’ hyper link on the login screen
But then I have to first enable the email part which I do not use
anyway thanks for your fast reply
system
4
I get same error(These credentials do not match our records.)
when I want login, only way for login is forget password!
please help for this issue
5
Are you self hosting or using invoiceninja.com.
If you’re sure the email\password are correct you may want to try testing with a different browser.
