Can't get invoice preview/download to work when behind NginxProxyManager
Version ie <v5.10.46>
Docker
Checklist
  • Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja
  • Have you searched existing issues?yes
  • Have you inspected the logs in storage/logs/laravel.log for any errors? yes
Describe the bug
PDF preview/download/print does’nt work when access the selfhosed server via reverseproxy manger like NPM
Steps To Reproduce
Create a client from client tab, then go to invoice and select a product/service and scroll down in invoice section, pdf preview keeps on loading until it fails. Can’t get to print nor download or preview when we try to access it behind the NPM(nginxproxymanger). i’ve tried setting domain name and IP too in trusted proxy in ENV
Expected Behavior
I exepected it to load and able to download as it normally does when access the same page via direct IP address like 192.168.0.44:80.
Additional context
Screenshots
Logs
192.168.160.4 - 11/Nov/2024:14:29:02 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:03 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:05 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:05 +0000 “POST /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:30 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:32 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:35 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:36 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:29:37 +0000 “POST /index.php” 200
2024-11-11 14:29:40,202 INFO reaped unknown pid 724 (exit status 0)
2024-11-11 14:29:40,202 INFO reaped unknown pid 726 (exit status 0)
2024-11-11 14:29:40,202 INFO reaped unknown pid 729 (exit status 0)
2024-11-11 14:29:40,202 INFO reaped unknown pid 730 (exit status 0)
192.168.160.4 - 11/Nov/2024:14:29:48 +0000 “GET /index.php” 200
2024-11-11 14:29:50,243 INFO reaped unknown pid 888 (exit status 0)
2024-11-11 14:29:50,243 INFO reaped unknown pid 886 (exit status 0)
2024-11-11 14:29:50,244 INFO reaped unknown pid 891 (exit status 0)
2024-11-11 14:29:50,244 INFO reaped unknown pid 892 (exit status 0)
2024-11-11 14:30:00 Running [queue-size-job] … 30.92ms DONE
2024-11-11 14:30:00 Running [stale-invoice-job] … 5.99ms DONE
2024-11-11 14:30:00 Running [Callback] … 19.86ms DONE
2024-11-11 14:30:00 App\Jobs\Subscription\CleanStaleInvoiceOrder … RUNNING
2024-11-11 14:30:00 App\Jobs\Ninja\QueueSize … RUNNING
2024-11-11 14:30:00 App\Jobs\Ninja\QueueSize … 15.24ms DONE
2024-11-11 14:30:00 App\Jobs\Subscription\CleanStaleInvoiceOrder 27.72ms DONE
192.168.160.4 - 11/Nov/2024:14:30:20 +0000 “POST /index.php” 200
192.168.160.4 - 11/Nov/2024:14:30:20 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:30:23 +0000 “POST /index.php” 200
2024-11-11 14:30:25,707 INFO reaped unknown pid 1046 (exit status 0)
2024-11-11 14:30:25,707 INFO reaped unknown pid 1048 (exit status 0)
2024-11-11 14:30:25,708 INFO reaped unknown pid 1051 (exit status 0)
2024-11-11 14:30:25,708 INFO reaped unknown pid 1052 (exit status 0)
INFO No scheduled commands are ready to run.
192.168.160.4 - 11/Nov/2024:14:31:07 +0000 “PUT /index.php” 200
192.168.160.4 - 11/Nov/2024:14:31:07 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:31:09 +0000 “PUT /index.php” 200
192.168.160.4 - 11/Nov/2024:14:31:09 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:33:07 +0000 “GET /index.php” 200
2024-11-11 14:35:00 Running [queue-size-job] … 28.45ms DONE
2024-11-11 14:35:00 Running [Callback] … 21.82ms DONE
2024-11-11 14:35:01 App\Jobs\Ninja\QueueSize … RUNNING
2024-11-11 14:35:01 App\Jobs\Ninja\QueueSize … 6.91ms DONE
192.168.160.4 - 11/Nov/2024:14:37:26 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:37:29 +0000 “GET /index.php” 200
192.168.160.4 - 11/Nov/2024:14:37:31 +0000 “GET /index.php” 200
2024-11-11 14:38:33,632 INFO reaped unknown pid 1236 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1238 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1262 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1241 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1242 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1268 (exit status 0)
2024-11-11 14:38:33,634 INFO reaped unknown pid 1286 (exit status 0)
2024-11-11 14:38:33,635 INFO reaped unknown pid 1368 (exit status 0)
2024-11-11 14:38:33,635 INFO reaped unknown pid 1261 (exit status 0)
192.168.160.4 - 11/Nov/2024:14:37:32 +0000 “POST /index.php” 500
192.168.160.4 - 11/Nov/2024:14:37:37 +0000 “GET /index.php” 500
2024-11-11 14:38:38,166 INFO reaped unknown pid 1423 (exit status 0)
2024-11-11 14:38:38,166 INFO reaped unknown pid 1438 (exit status 0)
2024-11-11 14:38:38,167 INFO reaped unknown pid 1520 (exit status 0)
2024-11-11 14:38:38,167 INFO reaped unknown pid 1416 (exit status 0)
2024-11-11 14:38:38,167 INFO reaped unknown pid 1396 (exit status 0)
2024-11-11 14:38:38,167 INFO reaped unknown pid 1397 (exit status 0)
2024-11-11 14:38:39,169 INFO reaped unknown pid 1391 (exit status 0)
2024-11-11 14:38:39,169 INFO reaped unknown pid 1393 (exit status 0)
2024-11-11 14:38:39,169 INFO reaped unknown pid 1422 (exit status 0)
Are there any details about the error in storage/logs?
Hi, here are the logs from storage directory
@hillel
If you’re using the SnapPDF PDF generator you may want to try changing to hosted_ninja
Now i lost preview in both via proxy and directly via IP.
You may want to try using telnet from the server to check that the host/port is reachable
All my ports are free and i can very well reach with just ip and port
It may help to add TRUSTED_PROXIES=* to the .env file
its been added since default.
ill attach my compose and env.
please go through
services:
server:
container_name: invoiceninja-server
image: nginx
restart: always
env_file: env
volumes:
# Vhost configuration
#- ./config/caddy/Caddyfile:/etc/caddy/Caddyfiledocker-com
- ./docker/app/public:/var/www/app/public:ro
depends_on:
- app
# Run webserver nginx on port 80
# Feel free to modify depending what port is already occupied
ports:
- “867:80”
- “4413:443”
networks:
  - invoiceninja
extra_hosts:
  - "invoice.skynetlab.in:192.168.66.10 " #host and ip
app:
container_name: invoiceninja-app
env_file: env
restart: always
volumes:
- ./config/php/php.ini:/usr/local/etc/php/php.ini
- ./config/php/php-cli.ini:/usr/local/etc/php/php-cli.ini
depends_on:
  - db
networks:
  - invoiceninja
extra_hosts:
db:
image: mysql:8
container_name: invoiceninja-db
When running on ARM64 use MariaDB instead of MySQL
image: mariadb:10.4
For auto DB backups comment out image and use the build block below
build:
context: ./config/mysql
restart: always
env_file: env
volumes:
  - ./docker/mysql/data:/var/lib/mysql:rw,delegated
  # remove comments for next 4 lines if you want auto sql backups
  #- ./docker/mysql/bak:/backups:rw
  #- ./config/mysql/backup-script:/etc/cron.daily/daily:ro
  #- ./config/mysql/backup-script:/etc/cron.weekly/weekly:ro
  #- ./config/mysql/backup-script:/etc/cron.monthly/monthly:ro
networks:
  - invoiceninja
extra_hosts:
THIS IS ONLY A VALID CONFIGURATION FOR IN 4. DO NOT USE FOR IN 5.
cron:
image: invoiceninja/invoiceninja:alpine-4
volumes:
  # - ./docker/app/public:/var/www/app/public:rw,delegated
  # - ./docker/app/storage:/var/www/app/storage:rw,delegated
  # - ./docker/app/public/logo:/var/www/app/public/logo:rw,delegated
entrypoint: |
/bin/sh -c 'sh -s <<EOF
trap “break;exit” SIGHUP SIGINT SIGTERM
sleep 300s
while /bin/true; do
./artisan ninja:send-invoices
./artisan ninja:send-reminders
sleep 1d
done
EOF’
networks:
- invoiceninja
networks:
invoiceninja:
env file
IN application vars
APP_URL=https://192.168.66.10:867/
APP_KEY=base64:HCb7IFcne3iLSzAqxo/Zcf24ToG+lqBH9lukMW/G0Xk=
APP_DEBUG=false
REQUIRE_HTTPS=false
PDF_GENERATOR=snappdf
TRUSTED_PROXIES=*
QUEUE_CONNECTION=database
DB connection
DB_HOST=db
DB_PORT=3306
DB_DATABASE=ninja
DB_USERNAME=ninja
DB_PASSWORD=ninja
Create initial user
Default to these values if empty
[email protected]
IN_PASSWORD=changeme!
[email protected]
IN_PASSWORD=xxxxxxxxx
Mail options
MAIL_MAILER=log
MAIL_HOST=smtp.mailtrap.io
MAIL_PORT=2525
MAIL_USERNAME=null
MAIL_PASSWORD=null
MAIL_ENCRYPTION=null
MAIL_FROM_ADDRESS=‘[email protected]
MAIL_FROM_NAME=‘Self Hosted User’
MySQL
MYSQL_ROOT_PASSWORD=ninjaAdm1nPassword
MYSQL_USER=ninja
MYSQL_PASSWORD=ninja
MYSQL_DATABASE=ninja
GoCardless/Nordigen API key for banking integration
NORDIGEN_SECRET_ID=
NORDIGEN_SECRET_KEY=
V4 env vars
DB_STRICT=false
APP_CIPHER=AES-256-CBC
Sorry, I’m not sure
You may want to try one of the automated installers
@sharath
Did you ever solve this? We just started experiencing the issue about two weeks ago after years of successful use. Also I can’t login either when I’m on the other side of the reverse proxy, but I can view links.
