Cant generate reports
v5.10.62 - Zip - Self-Hosted
I can’t generate reports. When I select something from the “report” and select a “range” or “client” and either press Export or Review, the “processing” never stops and end up with an error.
Thanks for the help.
Christopher.
Are there any errors in storage/logs?
Note: you may want to try with the desktop app.
I checked the logs and all it says is “production.INFO: updating currencies”.
Also, have you tried the desktop app?
The chrome console it say’s the following:
bundle.fe9035ae.js:143 POST https://invoice.xxxxx.ca/api/v1/exports/preview/0180d663-ceaf-4f4c-9bd7-c9d8a9eebc9f 409 (Conflict)
bundle.fe9035ae.js:382
  1. DD {message: ‘Request failed with status code 409’, name: ‘AxiosError’, code: ‘ERR_BAD_REQUEST’, config: {…}, request: XMLHttpRequest, …}
Just tried the Desktop App, but to be very honest, I rather use the web page full time.
Does it work in the desktop app? I’m trying to help you find the source of the problem.
This looks like it may be the same error:
Sorry forgot to mention, yes the Desktop App works when i do reports.
Seems like the link you send for the " Live reports preview #1299" is exactly what I have, but it is my understanding that on shared hosting it’s a bust.
Thank you, that’s helpful to know.
I suggest following up on that issue.
It could be part of a background process—try enabling debug mode for more detailed logs.
