Can't edit invoice design?
I’ve created an invoice design but when I go to customize and click on my design, there isn’t any option to edit it anymore? Only archive or delete.
Something has changed because I was able to easily edit an existing design before and now I can’t figure out how to.
If you click the checkbox next to ‘Create’ you’ll be able to edit.
Thanks @hillel , I see what happened. It was stuck in multi-select mode, even when I navigated away and came back. I think there is a bug here.
It should revert back to normal (non multi select mode) after navigating away from that page and returning.
Agreed, this is on my list to fix.
