Thanks Hillel!
I manually copied over v5.7.0 (zip), I’m getting blank white page when I go to URL, log shows this error now:
[Mon Aug 21 13:42:15.096751 2023] [proxy_fcgi:error] [pid 1420446:tid 140540148803328] [remote 98.63.16.68:59631] AH01071: Got error ‘PHP message: PHP Fatal error: Uncaught ReflectionException: Class “view” does not exist in /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php:889\nStack trace:\n#0 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(889): ReflectionClass->__construct()\n#1 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(770): Illuminate\Container\Container->build()\n#2 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(856): Illuminate\Container\Container->resolve()\n#3 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(706): Illuminate\Foundation\Application->resolve()\n#4 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(841): Illuminate\Container\Container->make()\n#5 /var/www/clients…; PHP message: PHP Fatal error: Uncaught ReflectionException: Class “view” does not exist in /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php:889\nStack trace:\n#0 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(889): ReflectionClass->__construct()\n#1 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(770): Illuminate\Container\Container->build()\n#2 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(856): Illuminate\Container\Container->resolve()\n#3 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(706): Illuminate\Foundation\Application->resolve()\n#4 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(841): Illuminate\Container\Container->make()\n#5 /var/www/clients…’
August 21, 2023, 6:48pm
42
Can you try running php artisan optimize
When I run “php artisan optimize” via command prompt I get:
Composer detected issues in your platform:
Your Composer dependencies require a PHP version “>= 8.1.2”. You are running 7.4.33.
PHP Fatal error: Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 8.1.2”. You are running 7.4.33. in /var/www/clients/client1/web1/web/billing/vendor/composer/platform_check.php on line 24
My server runs Debian 11 which ships with php 7.4 as default. They don’t recommend changing default php version on the system. I have additional php versions installed: php 8.1 & php 8.2, which I assigned to the website where invoice ninja is installed.
August 22, 2023, 6:13am
44
The app requires both the web and CLI versions of PHP to be >= 8.
when I run “php8.2 artisan optimize” I see
In Container.php line 891:
Target class [db.schema] does not exist.
In Container.php line 889:
Class “db.schema” does not exist
I copied my working installation v5.3.15 to another subfolder and it works w/o issues
I downloaded latest zip v5.7.4 and overwrote all the files (except ones with .)
I get HTTP ERROR 500
When I run “php8.1 artisan cache:clear” or “php8.1 artisan optimize” I get error
In Application.php line 827:
Class “Coconuts\Mail\PostmarkServiceProvider” not found
Also, apache error log shows:
[Fri Aug 25 16:28:17.399851 2023] [proxy_fcgi:error] [pid 4124152:tid 139697823905536] [remote 99.99.99.99:60644] AH01071: Got error ‘PHP message: PHP Fatal error: Uncaught ReflectionException: Class “translator” does not exist in /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php:912\nStack trace:\n#0 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(912): ReflectionClass->__construct()\n#1 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(795): Illuminate\Container\Container->build()\n#2 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(933): Illuminate\Container\Container->resolve()\n#3 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(731): Illuminate\Foundation\Application->resolve()\n#4 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(918): Illuminate\Container\Container->make()\n#5 /var/www/c…PHP message: PHP Fatal error: Uncaught ReflectionException: Class “translator” does not exist in /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php:912\nStack trace:\n#0 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(912): ReflectionClass->__construct()\n#1 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(795): Illuminate\Container\Container->build()\n#2 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(933): Illuminate\Container\Container->resolve()\n#3 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Container/Container.php(731): Illuminate\Foundation\Application->resolve()\n#4 /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(918): Illuminate\Container\Container->make()\n#5 /var/www/c…’
August 25, 2023, 10:14pm
48
It may help to run composer install
Thanks @hillel I did, I still get same issues. Any other ideas?
root@server:/var/www/clients/client1/web1/web/billing# composer self-update
You are already using the latest available Composer version 2.5.8 (stable channel).
root@server:/var/www/clients/client1/web1/web/billing# php8.1 artisan optimize
root@server:/var/www/clients/client1/web1/web/billing# php8.1 artisan cache:clear
Progress.
I was able to run:
“php8.1 -f /usr/local/bin/composer update”
go to https://mywebsite/update?secret=mysecretkeyhere
Now I can get to login screen, but when I enter user & password, I still see: 500: Server Error
August 27, 2023, 12:59am
51
I see below in /storage/logs/laravel.log
[2023-08-26 20:29:13] production.ERROR: SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘billingv5.purchase_orders’ doesn’t exist (Connection: mysql, SQL: select * from purchase_orders where purchase_orders.company_id in (2) and created_at >= 1970-01-01 00:00:00) {“userId”:1,“exception”:"[object] (Illuminate\Database\QueryException(code: 42S02): SQLSTATE[42S02]: Base table or view not found: 1146 Table ‘billingv5.purchase_orders’ doesn’t exist (Connection: mysql, SQL: select * from purchase_orders where purchase_orders.company_id in (2) and created_at >= 1970-01-01 00:00:00) at /var/www/clients/client1/web1/web/billing/vendor/laravel/framework/src/Illuminate/Database/Connection.php:801)
August 28, 2023, 9:22am
53
It may help to run php artisan migrate
hillel:
php artisan migrate
thank you @hillel - that fixed the issue, it works now.
August 28, 2023, 8:49pm
55
