Hi there,
I have been trying to setup Invoice Ninja v.5.8.51 on Ubuntu 22.04 LTS and NGINX at least a dozen of times.
No matter what I try, I keep on getting the same error message over and over again:
The command "mysql --user="${:LARAVEL_LOAD_USER}" --password="${:LARAVEL_LOAD_PASSWORD}" --host="${:LARAVEL_LOAD_HOST}" --port="${:LARAVEL_LOAD_PORT}" --database="${:LARAVEL_LOAD_DATABASE}" < "${:LARAVEL_LOAD_PATH}"" failed.
Exit Code: 1(General error)
Working directory: /usr/share/nginx/invoiceninja/public
Output:
Error Output:
ERROR 2002 (HY000): Received error packet before completion of TLS handshake. The authenticity of the following error cannot be verified:
1130 - Received error packet before completion of TLS handshake. The authenticity of the following error cannot be verified … ```
I closely followed the instructions as set out here [https://forum.invoiceninja.com/t/install-invoice-ninja-v5-5-on-ubuntu-22-04/13272](https://forum.invoiceninja.com/t/install-invoice-ninja-v5-5-on-ubuntu-22-04/13272). What am I missing?
Nextcloud and Matomo run flawlessly on the same webserver, all applications are being served as vhosts with php8.1-fpm as upstream server:
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name invoiceninja.undisclosed-domain.com;
client_max_body_size 64M;
# This if statement will forcefully redirect any connection attempts to explicitly use the domain name.
# If not, and your DNS doesn’t provide IP address protection, accessing the server with direct IP can
# cause glitches with the services provided by the app, that could be security, or usability issues.
if ($host != $server_name) {
return 301 https://$server_name$request_uri\;
# Here, enter the path to your invoiceninja directory, in the public dir. VERY IMPORTANT
# DO NOT point the root directly at your invoiceninja directory, it MUST point at the public folder
# This is for security reasons.
root /usr/share/nginx/invoiceninja/public\;
gzip on\;
gzip_types application/javascript application/x-javascript text/javascript text/plain application/xml application/json\;
gzip_proxied no-cache no-store private expired auth\;
gzip_min_length 1000\;
index index.php index.html index.htm\;
ssl_certificate /etc/letsencrypt/live/invoiceninja.undisclosed-domain.com/fullchain.pem\; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/invoiceninja.undisclosed-domain.com/privkey.pem\; # managed by Certbot
# include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
ssl_session_cache shared:SSL:10m\;
ssl_session_timeout 30m\;
ssl_ciphers 'AES128+EECDH:AES128+EDH:!aNULL'\;
ssl_prefer_server_ciphers on\;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2\;
charset utf-8\;
# Load configuration files for the default server block.
include /etc/nginx/default.d/*.conf;
location / {
try_files $uri $uri/ /index.php?$query_string\;
if (!-e $request_filename) {
rewrite ^(.+)$ /index.php?q= last\;
location ~ \.php$ {
\# Here we pass php requests to the php8.1-fpm listen socket.
\# PHP errors are often because this value is not correct.
\# Verify your php8.1-fpm.sock socket file exists at the below directory
\# and that the php8.1-fpm service is running.
fastcgi_pass unix:/var/run/php/php8.1-fpm.sock\;
fastcgi_index index.php\;
include fastcgi_params\;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name\;
fastcgi_intercept_errors off\;
fastcgi_buffer_size 16k\;
fastcgi_buffers 4 16k\;
location ~ /\.ht {
deny all\;
location = /favicon.ico { access_log off; log_not_found off\; \}
location = /robots.txt { access_log off; log_not_found off\; \}
access_log /var/log/nginx/ininja.access.log\;
error_log /var/log/nginx/ininja.error.log\;
sendfile off\;
server {
listen 80;
add_header Strict-Transport-Security max-age=2592000;
rewrite ^ https://$server_name$request_uri? permanent;
What is probably misconfigured? Please advise …
Jens
