Can I take one payment and split it between multiple payment gateways
Hi -
Is it possible to take a clients payment and split it between two gateways or between a gateway and a bank account? My use case is My client buys an all inclusive package from me and pays me $100 for it. I want $75 of it to go through one payment gateway and $25 of it to another to comply with specific laws governing the sale of alcohol in some US States.
Thanks!
One option may be to set the partial/deposit field to 25, your client could then make two separate payments.
If the amounts are always the same you could use min/max gateway limits to ensure the payment is processed with the correct gateway.
Unfortunately the amounts will be different each time so the min/max probably wont work. If I use the partial deposit field (which we use all the time) how do I set that to go to one specific payment gateway verses the remaining payment which needs to go to another gateway.
The only solution I can think of is using min/max to limit the available gateways.
