Hi, I would like to attach / link individual expenses to a project (not for invoicing) but to track my spending for individual projects. Can I do that in invoice ninja? Thanks
Yes, it’s supported in the latest version of the app.
Hi Hillel, Thanks. Can I also do that on the desktop app? Also, om my desktop I don’t see the time tracker buttom visible when I’m looking at tasks. Is there a way to turn it on? Thanks
Can you recommend a good video tutorial for me? Thanks
Yes, it’s also supported in the desktop app.
Do you want to post a screenshot of what you’re seeing?
You can find our videos here: https://www.youtube.com/@appinvoiceninja/videos
If you click ‘More actions’ you’ll see an option to start the task.
Thanks Hillel but is there any way I can get my screen to look like this with the time tracker and projects tabs visible?
The projects option is now in the main left navigation sidebar.
There isn’t a separate time tracker app but we do provide a Chrome extension.
Thank you Hillel I really appreciate your support
