Can I choose my subdomain?
Hello. I just migrated over to v5 and I see there’s an option to choose a subdomain. The default is “mumebage” which I assume is a gibberish placeholder. When I try to change this in the client portal settings, the “save” button is grayed out and I can’t save changes.
Is this normal? Can I make a change to this on the free tier?
There’s a workaround to change the subdomain on the free plan. If you temporarily clear the company name on Settings > Company Details you’ll see the setup popup on the dashboard which will enable you to change the subdomain.
Terrific! I got that to work. For future reference, I cleared out my name in the top line of company details. Saved it, returned to dashboard. Then the popup asked for my business name and subdomain.
Then I could return to settings>client portal and see that my subdomain had changed.
This issue exists in the Pro plan as well. I am using the Linux desktop app and I was unable to update my client portal subdomain within Settings, however, I followed @maddogmovies advice above and it worked.
Sorry for the trouble, this is a bug in the Linux app. It will be corrected in the next version of the app.
