I need support
https://meinfamilienfreund.de/buy_now?account_key=[somenumbersandcharacter]&product_id=2
doesn’t work
404 not found
Where i can get the right account_key? Is it a api-key?
I need support
doesn’t work
404 not found
You can generate a buy now link in the app on Settings > Client Portal
It may be from your web server configuration, it looks like /public/buy_now/ is being redirected to /buy_now.
We recommend removing /public from the URL by mapping the folder to the web root.
Thank you.
Sometimes it is so easy.
Why is this being redirected ?
My Buy Now buttons do not work and this makes no sense. The link generated from the Buy Now button creator inside the admin provides us with the URL
https://invoices.pixsell.io/public/buy_now/?account_key=9upqftn8063wyh7sogxg7dkyygxwsqec&product_id=1
However when this is inserted into a browser it redirects to
https://invoices.pixsell.io/buy_now?account_key=9upqftn8063wyh7sogxg7dkyygxwsqec&product_id=1
And we get a 404 not found.
There is no redirect from anything no .htaccess file and all of this was working previously.
Any ideas why this is now failing ? Why is it being redirected ?
EDIT:
Just to add this however DOES WORK ??
https://invoices.pixsell.io/public/payment/xt1fqabvlw6ddeqb20nokbwxshr8krlz/credit_card
Try removing the forward slash after ‘buy_now’ in the first link
