InvoiceNinja version: v5.6.4-C121
I would like the buttons located at the bottom left to be visible only for admins (error button, contact us, errors, etc.), is this possible?
Thank you in advance for your help,
Stef
Stef
Sorry, it isn’t supported.
Note: when clicking the about button most of the options in the dialog are only visible to admins.
If so, is it possible to remove it?
Thank you,
Steve
We can look into only showing the errors to admins.
Can you tell me how to do it?
Thanks again for your time,
You would need to modify the code and rebuild the app.
Is there a procedure I can follow somewhere in the documentation?
Thank’s,
We don’t recommend this as you would need to keep rebuilding the app to keep up with the latest changes. Can you confirm that you aren’t reselling the app?
No, the goal is that for some very very novice users who I will allow to use the platform, if I leave a lot of buttons (options to send messages), they will get lost and they risk sending messages to you for no reason.
This is the reason why I wanted to remove these options. ![]()
Thank’s,
