I’m using the self-hosted version of invoice ninja, v.4.5.10. I couldn’t find any relevent laravel-error.log errors.
When I select Letter for the page size, the right margin width is set larger than what it is for line items. So, the orange invoice # box formats fine to the wider margin, but the blue header ends up cutting off the “Line Total” to “Line Tot”, and it looks like the balance due line also has the wider margin width, although the amount is not cut off.
This is a clean installation, and I have only entered business information, logo, payment gateway & my first couple invoices.
Any suggestions how I might go about fixing this formatting error? If I set the page size to A4, the formatting error goes away, but I need to use Letter size.
I can post a screen shot if that helps, just let me know where I should upload the image, thx!
Just a quick update to say I noticed the native “business template” formatting on Letter sized pages forced the invoice date line on to a second line (insufficient space). Here’s the fix I put in place to extend the invoice date line sufficiently:
I’ll put it together with the fix for the “line total” problem so both fixes are below:
Under Customize Design–>Content
navigate the folder tree to change the following four values:
array–>2–>canvas–>0–> set w to a value of 531
array–>4–>columns–>1–>stack–>1–>canvas–>0–> set w to a value of 205
array->1->columns->1->canvas->0->set w to a value of 191
array->1->columns->2->table->widths->set 1 to a value of 86
