Logo not display on invoice and also in the setting > company details>log. I installed and checked on different shared hosting.
The most solution for this problem is to correct the APP_URL in the .env file and then re-upload the logo.
it’s the same
APP_URL=“https://billing.jetax.com”
hosted URL: https://billing.jetax.com/index.php
I suggest confirming that mod_rewrite is enabled.
Yes it enabled already
I wouldn’t expect to see index.php in the URL, it typically means mod_rewrite isn’t working.
If you’ve made any changes it may help to re-upload the logo.
Yes, it shows index.php when I visit the URL. I just changed the app name and also installed it many times but have the same issue.
Can you please copy/paste the URL for the logo from the error in the browser console?
thank you it’s working now.
Glad to hear it, how did you fix it?
I change the storage folder permission and it worked.
Awesome, thanks for sharing the solution!
