I have several invoices that for some reason when I edit them I can see the PDF as Preview without problems, but when I print them they come out blank. I have noticed that all the blank ones start with a line that says: pdf;base64 Do you know what could be happening?
We’ve had a couple of reports of this, we can’t recreate but there may be some intermittent issue here. We’ve made some changes with the hosted pdf generator. Can you please advise if this is still happening.
How can we test the changes you did on the hosted generator? Did you deployed a new version?
As I mentioned on slack, I encountered the same issue. Switching to snappdf solved the issue. I don’t know what’s the advantages/disadvantages of staying with snappdf or reverting to the (corrected) hosted_ninja.
