I just installed 5.11.41 and I have a blank screen after setup. I am also unable to login to desktop app. I get error 401: Unauthorized • These credentials do not match our records. I am pretty sure they are same from setup
Version ie <v5.10.30>
Checklist
Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja ?
Have you searched existing issues?yes
Have you inspected the logs in storage/logs/laravel.log for any errors?production.INFO: db fails
Describe the bug
blank page on url : http://localhost/invoiceninja
and http://localhost/invoiceninja/index.php
Steps To Reproduce
Expected Behavior
Additional context
Screenshots
Logs
February 23, 2025, 10:11pm
If you installed the app by checking out the code from GitHub it doesn’t include the React web app, the release tar does include it.
If you’re seeing a 401 it likely means the email or password is incorrect, you can check the email in the users table in the database.
What folder is the react app located?
And is the database in the .env file?
February 23, 2025, 11:27pm
4
It’s included with the release tar
The .env file is used to configure the application, including the database credentials
In the .env file I see credentials I used to login on setup page but not the e-mail and password that i provided.
I believe I downloaded the .tar file (the top one), I just wanted to verify if anybody knew where the file location is supposed to be.
I do see a react file in the xampp/invoiceninja
February 24, 2025, 5:07pm
6
The user’s email/password are stored in the database, not the .env file.
You may want to review the app’s license:
The leading free source available online invoicing app for freelancers & businesses. Invoice, accept payments, track expenses, & time-tasks
