How to force a line break and a blank line in the global texts (invoice conditions, offer conditions, …)?
You should be able to use <br/> to add line breaks
@ben do you have any thoughts?
Is markdown setting enabled? (Settings > Account management > Enable Markdown)
Thanks. I will let you know once I have more information on this.
The first break is defining the end of the paragraph.
You probably need another (i.e. a second <br> ) to make the actual blank line…
