I currently have a VPS with 2 v4.5.44 installs on it. The VPS is acting up and I cannot get remote SSH to work so I have to use the remote console which is a royal PITA. I am looking to migrate my two v4 installs to my Docker setup. I also want to utilize my NGINX Proxy Manager to proxy the stuff over to the docker containers. I have tried unsuccessfully in the past to migrate from v4 to v5 and even to a v4 to v4 direct copy. I am assuming it was mostly because I was running through the NPM and Invoice Ninja already has a proxy (Caddy or Nginx) itself.
What would be the best/most direct way to make this happen without reinventing the wheel?
Second part, is the upgrade to v5 better now? Not sure how much longer v4 will be supported but last time I tried v5 it was a hot mess.
At the time I tried upgrading I was current. It was probably 6+ months ago I tried but ultimately ended up sticking with my self hosted v4 install. I tried upgrading about a month or so ago and it broke more stuff on my v4 instance so I have been sticking with the version I am on for now. I will try upgrading again and see what happens.
Any input on how to get it going behind my NPM proxy and not rely on the caddy or its own nginx? I guess I am just clueless on that part.
