I am running an AWS instance with multiple accounts under whm. I have IN installed under a subfolder of one website account in WHM. Is this where I need to configure or create the cron or should it be created on the AWS instance itself? Still having issues getting the cron installed/started.
Do I create the cron job in whm or in cpanel for the specific account? In WHM, this is the only thing I see related to crons… " Configure cPanel Cron Jobs"
If you click the red triangle, is it still saying “crons aren’t running”, or is it complaining about something else? If it’s still cron, try removing the " >> /dev/null 2>&1" part for a while. You should then receive the output of the cron jobs by mail. (Receiving a mail from cron every minute will turn into a nuisance quickly, so be prepared to put it back in after a few minutes.)
Without the output redirection cron should generate one email every time the job is run, so every minute in your case. Either emails are delivered to an unknown place or cron ain’t running.
Ok so,
My CRONS are running and I am hosting Invoice Ninja in a sub folder directly off of the public html folder. Invoice Ninja STILL won’t recognize that the crons are running…
