It does not look like there is anything there. I also noticed that when I wanted to add a payment method, it gave me the following message from Payfast. I attached screenshots.
Is there any information in payfast about this error? I’ve tested against their sandbox environment and cannot reproduce this, however I don’t have production credentials so there may be something we are missing here.
OK, so I went into the dashboard of Payfast under the settings > recurring billing
I then enabled tokenization.
It seems that I can now create a payment method inside the client dashboard. I am going to run another recurring payment to test it again. Here is a screenshot. I hope this works.
For what it’s worth, I’ve never been able to get auto-bill to a credit card on file to work either. I use WePay… I gave up trying to fix it. The invoices are created and sent each month and I have to go in and open each invoice manually, open the customer portal, click all the buttons and links to pay the invoice manually using the customer’s card on file. It’s really maddening but I don’t have time to work through this issue, so I have just dealt with it each month.
I doubt it’s a setting in WePay since it doesn’t even attempt to charge the customer’s card, ever. It just creates the invoice. Yes I DO have the option set to auto-bill on the recurring profile by the way and the customer DOES have a card on file since I charge to it manually each month. This is for each customer that I use recurring billing for, not just one.
Thanks, I changed it and we will see if it works now on the first of next month.
Thing is though the Send Date and Due Date are the same on these invoices. So… Not sure why this setting would work any different but I guess if it fixes my issue, I don’t care lol
The recurring invoice may generate before the “due_date” autobill process runs. Changing to On Send Date will resolve the issue. Let us know if you have any troubles.
