Hi
I am trying to find a way to attach an image to an expense. Many receipts fade over the year and it would be great to be able to attach an image of a receipt to an expense for tax. Is this possible?
Many thanks
Hi
Many thanks
When you enter an expense, there’s a field down at the bottom where you can drag & drop documents. Should work for images just fine. I’ve put PDFs in there before and haven’t had an issue.
Note: if you’re using invoiceninja.com this feature requires an enterprise plan.
