I’ve had a look into this. I’m not sure we’ll be able to support showing the expense documents within the documents tab in the client portal, however i believe we can support showing the expense documents on the invoice view itself within the client portal.
Hi @david
That would be great too, thanks! That’s what I initially thought: my expense PDFs will be merged with the invoice PDF, but it didn’t work either.
So the “Add Documents to Invoice” option isn’t working currently?
This option also attached the documents to the invoice email which does function correctly, the missing functionality was displaying the documents in the client portal.
