I can’t seem to find the proposals feature anywhere, I’ve seen a few videos of people using it but I can’t seem to find it, using docker version, latest
Proposals were supported in the v4 version of the app but haven’t been implemented in the v5 app.
Thanks for the reply, are there big changes between 4 and 5? So if I want the proposals I’ll have to run the v4 version of the app?
v4 and v5 are completely separate apps, the only option for proposals would be to use the v4 app.
Note: the PDF system is much more customizable in v5 if you know HTML/CSS.
Thanks for the information @hillel Is it possible to use the dockerfile to run the v4 version of the app?
