Hey guys, looking for some assistance related to the API functionality and what we can/cannot achieve. Also hoping to hire someone who can implement some custom API for us. Let me know if you or someone you know might be able to help. Thanks!
If you have any specific questions I can try to help.
Hi Hillel,
Is it possible to import quotes by line item via CSV?
I believe this is supported using the web app.
Any documentation? Or import template?
You can use any format CSV file, after you upload the file you’ll be able to map the columns.
The suggestion provided by Hillel to use the web app for importing quotes by line items should work well.
If however you are wanting to still further customize the process by using the InvoiceNinja API I would be glad to help you out, as I have worked on some complex projects in the past utilizing the InvoiceNinja API
You can reach out to me on my email here
Colin
Hi @Colin2 , would you be able to DM your email? I might have a project in the work in 2024. Thank you
