i try to install v5 and although I set up everything ok in the forst setup screen, and all the tests are completed ok, i keep getting returned to the top of the screen to re-enter the setup details.
Anyone know why ?
Anyone know why ?
Are there any error in the web server error logs or the application logs in storage/logs/
[2021-03-15 08:23:34] production.INFO: The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password="${:LARAVEL_LOAD_PASSWORD}" --host="${:LARAVEL_LOAD_HOST}" --port="${:LARAVEL_LOAD_PORT}" --database="${:LARAVEL_LOAD_DATABASE}" < “${:LARAVEL_LOAD_PATH}”" failed.
Exit Code: 1(General error)
Working directory: /home/xxx/xxx/public
ERROR 1050 (42S01) at line 9: Table ‘accounts’ already exists
[2021-03-15 09:38:43] production.INFO: The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password="${:LARAVEL_LOAD_PASSWORD}" --host="${:LARAVEL_LOAD_HOST}" --port="${:LARAVEL_LOAD_PORT}" --database="${:LARAVEL_LOAD_DATABASE}" < “${:LARAVEL_LOAD_PATH}”" failed.
[2021-03-15 09:59:21] production.INFO: The command “mysql --user=”${:LARAVEL_LOAD_USER}" --password="${:LARAVEL_LOAD_PASSWORD}" --host="${:LARAVEL_LOAD_HOST}" --port="${:LARAVEL_LOAD_PORT}" --database="${:LARAVEL_LOAD_DATABASE}" < “${:LARAVEL_LOAD_PATH}”" failed.
ERROR 1813 (HY000) at line 1604: Tablespace for table ‘xxx_invoicedb.vendors’ exists. Please DISCARD the tablespace before IMPORT.
I deleted all tables in the database before retrying but the problem remains.
Maybe try recreating the database?
I’ve just had exactly the same issue this morning on our test server. I must have recreated the DB 6 times to no avail (but did discover a bug in the setup page script which has been fixed)
We use Cloudflare as a CDN. On a whim I turned off their caching engine so my server is sending the pages rather than Cloudflare.
Problem solved.
So if you are using a cache, try turning it off.
