Adding react to Softaculous install
Hi there, so ive got invoice ninja installed via Softaculous, and its working fine except the logos wont upload.
I read somewhere to try the react app instead, but that just gives a 404 when trying to access react,
So then i found out Softaculous apparently doesnt add support for the react app. Can anyone direct to me what files i need to add and where to add the react app onto my install?
i dont want to accidentally overwrite anything because i have all of this financial years invoices already in there. Any ideas where to start carefully on this? thanks
v5.9.5-C160
The React app is included with the Softaculous install, I’m not sure why you’re seeing a 404.
If the logo isn’t loading I suggest checking the network tab in the browser console to check the logo URL.
I gave up on the logo stuff, and made a separate company for the new logo, instead of using groups like I was trying to.
However I really like the look of react and would still love to get that working? any ideas of where I can start looking for the issue? thanks heaps for the reply
One potential problem is that you’re using a much older version of the app.
