Hi…I would like to include Payment QR code and mobile number in the invoice pdf …Is there any option to do that?
no docs, but essentially you can embed any html/js into the invoice design to make this work.
Hey!
I saw that there’s $spc_qr_code (SPC formatted QR code) in the documentation. I guess that’s the Swiss Payments Code QR format, but it doesn’t print the QR code, just the values.
Is there an easy way to create a QR Code?
thanks a lot!
Hi…I found the work around… create .jpg QR code file using external QR code generator then add that image as a footer to custom invoice using image src html div.
Thanks @rragesh007, I’m doing the same now.
Any idea where to set the bank account (IBAN) that’s used in $spc_qr_code (SPC formatted QR code)?
I was at the same point and started digging in the source code. Here’s what you have to do:
- In settings, under custom fields → company, name the first field IBAN or any other name. But it’s important that it is the first field.
- Then in settings → company details → details, the newly created field IBAN should appear. Put your IBAN here and save.
I hope you can get it to work with this information. Of course, some more documentation on that would have been helpful.
I want to do the same but I don’t have any knowledge in programming is there any change to explain this step by step? Thanks!
Hey @Importjuan
See this thread here: QR code to scan and pay
Maybe that helps.
It sounds like you want to add a payment QR code and mobile number to your invoice PDF. One option would be to use a third-party service that generates payment QR codes and integrates them with your invoicing system. Some popular options are Square, PayPal, and Stripe. As for adding a mobile number, you could simply include it in the invoice text or as a footer. Alternatively, you could look into using a QR code generator that can encode both payment and contact information. Smart Engines is one such service, but there are many others out there. Hope that helps!
