When selecting a product from the drop-down menu to add it to the invoice, it won’t insert it. This is happening on a regular basis and it doesn’t happen to the same product all of the time. It happens to various different products. I have to save my invoice as a draft, log out and then back in before it will add the same product to the invoice. Then, when I go to add a second item to the same invoice, it does the same thing to this product.
Are there any errors in the browser console after selecting the product?
No, there are no errors at all
Which browser are you using/does using a different browser help?
I have used Chrome, Internet Explorer & Safari. It doesn’t matter which one I use, it still happens. I have cleared my cache & cookies, rebooted my modem and even restarted my computer. I have also tried on 2 different computers and same thing.
Are you using invoiceninja.com or are you self hosting?
If self hosting are you using the latest version?
I am using invoiceninja.com
I’m not sure, this is the first time I’ve heard of this problem.
If you’re able to send us a screencast of the problem it may help.
We’re deploying a new release tomorrow, maybe it will help?
Okay, I will wait until tomorrow and see if it still happens so I don’t waste your time troubleshooting the issue today. If it doesn’t fix the problem, I will sen a screencast.
Sounds like a plan
