I would like to add a custom field named “period” which would be the billing period. Example: May 15th to June 14th.
Is it possible ?
Is it possible ?
One option would be to add a custom invoice field on Settings > Invoice Settings
I have created 2 custom fields for the priod, but is it possible to have a field type “calendar” same as the field “Date” ?
is it possible to align the two boxes one below the other, as the image ?
Sorry, it isn’t supported
What is not suppoprted ? Align the two boxes one below the other or field calendar.
Neither changes are supported
Can you please share how you created these custom fields? The manual is unclear to me :-/
I would really appreciate it if you had a link to where this process is described in detail or a screen shot for me.
You can add custom fields on Settings > Invoice Details
Yes, I saw that and I read the manual and still, none of that helped me understand so I guess I’ll have to ask all the questions here one by one:
You can select which fields appear on the PDF on Settings > Invoice Design > Invoice Fields
The only options are text or a drop down
We don’t support translating custom fields
Thanks.
Where does this field get its info from??? See screenshot using the bold template. http://take.ms/WzO7t
The code says: text: $yourInvoiceLabelUC
I think you can use one design and just set one custom field at a time.
$yourInvoiceLabel is a translated label available to all designs and 'UC" makes it uppercase.
Thanks.
Regarding $yourInvoiceLabel:
I get that but where is the value pulled from?
I mean I can see that were I insert this label a value will be displayed but where does the value for this label come from?
Sorry for these newb questions but in the invoice design editor, this variable leads to “Your Invoice” when using the tempalte BOLD and “Invoice” when using the template called clean. Shouldn’t the same label pull the same data regardless of template?
No worries, I’m happy to help!
The text files are in resources/lang/
Note: they’re auto-updated from this project.
Thanks a lot for the valuable help.
