Adding Custom Bank Account
Dear Expert,
May I know how can add a local Bank account to the system? As my local bank is not listed in the dropdown.
Ant
Just to clarify, is this to import expenses or accept payments?
We use OFXHome to import expenses, you may be able to import the data as CSV.
Dear Hillel Coren,
Many thanks for your reply.
Yes. but my local bank is not in the list. Can i add it manually?
Do they support OFX?
We use this directory of OFX supported banks:
http://www.ofxhome.com/index.php/home/directory
If your bank supports OFX it should be possible to add it.
Dear Hillel Coren,
no. they are not.
Sorry, in that case I’d suggest importing as CSV.
