Hi.
In version 4 I had 2 companies on the same InvoiceNinja website. It worked well, but sometimes I got page not found when switching the company. I had to refresh/re-login and it worked. Never lost any data.
I remember talking about canceling this feature or something similar but I don’t remember exactly as it was way ago.
In version 5 I still see the Add Company option. So the question I have is it better to use 2 companies on same instance or separate instances? What are pros and cons?
Thank you
Br,
Dali
