Add another surcharge field until 9 surcharge field on invoice
hello Developer invoiceninja, i have problem when i’ll adding another surcharge field at invoice.
how to add surcharge field again until 7 surcharge field item?
Thank’s before.
Version ie <v5.10.30>
Checklist
Describe the bug
Steps To Reproduce
Expected Behavior
Additional context
Screenshots
Logs
Sorry, I don’t believe it’s supported
What if in v.5.12?
can it be supported?
Cause my Company need 9 item surcharge field add
I suggest following up on GitHub
Thank you for your response, Mr. Hillel
I feel helped by the quick response
