Is there any way to add a 2nd page into the PDF as plain text ? ( just with the terms and conditions )?
thanks
thanks
This should be doable by customizing the design, you can use "pageBreak": "after" to create the 2nd page.
https://github.com/bpampuch/pdfmake/issues/25
Let me know which design you’re using if you’d like more specifics.
i am using PLAIN template
can i just add text there or do i need to speficicly set that up in another way ?
its allmost 1 full a4 paper in text
maybe there is a good way just to do the page break and include a .doc file ?
Here’s an example of the plain design with a second page with additional text.
On the ‘Customize Design’ page switch from ‘Form’ to ‘Code’ and paste in the text below
[{“columns”:[{“stack”:"$accountDetails"},{“stack”:"$accountAddress"},[{“image”:"$accountLogo",“fit”:[120,80]}]]},{“columns”:[{“width”:340,“stack”:"$clientDetails",“margin”:[0,40,0,0]},{“width”:200,“table”:{“body”:"$invoiceDetails"},“layout”:{“hLineWidth”:"$none",“vLineWidth”:"$none",“hLineColor”:"#E6E6E6",“paddingLeft”:"$amount:10",“paddingRight”:"$amount:10"}}]},{“canvas”:[{“type”:“rect”,“x”:0,“y”:0,“w”:515,“h”:25,“r”:0,“lineWidth”:1,“color”:"#e6e6e6"}],“width”:10,“margin”:[0,30,0,-43]},{“style”:“invoiceLineItemsTable”,“table”:{“headerRows”:1,“widths”:"$invoiceLineItemColumns",“body”:"$invoiceLineItems"},“layout”:{“hLineWidth”:"$notFirst:1",“vLineWidth”:"$none",“hLineColor”:"#e6e6e6",“paddingLeft”:"$amount:8",“paddingRight”:"$amount:8",“paddingTop”:"$amount:8",“paddingBottom”:"$amount:8"}},{“pageBreak”:“after”,“columns”:["$notesAndTerms",{“width”:160,“style”:“subtotals”,“table”:{“widths”:[60,60],“body”:"$subtotals"},“layout”:{“hLineWidth”:"$none",“vLineWidth”:"$none",“paddingLeft”:"$amount:10",“paddingRight”:"$amount:10",“paddingTop”:"$amount:4",“paddingBottom”:"$amount:4"}}]},“Some text”]
i cant paste this in completely as it is
i managed to do it with the help that the code in the email was displayed correctly,
onfortunatly i cant copy paste everything in the document as it gives errors,
can i put in a document instead of text ? so that i put the back info text in a .doc on the root folder of my invoiceninja install and that it fetches that with every PDF creation ?
thanks
Sorry, we don’t support .doc files.
I think the problem is with the quotes, try the following:
[{"columns":[{"stack":"$accountDetails"},{"stack":"$accountAddress"},[{"image":"$accountLogo","fit":[120,80]}]]},{"columns":[{"width":340,"stack":"$clientDetails","margin":[0,40,0,0]},{"width":200,"table":{"body":"$invoiceDetails"},"layout":{"hLineWidth":"$none","vLineWidth":"$none","hLineColor":"#E6E6E6","paddingLeft":"$amount:10","paddingRight":"$amount:10"}}]},{"canvas":[{"type":"rect","x":0,"y":0,"w":515,"h":25,"r":0,"lineWidth":1,"color":"#e6e6e6"}],"width":10,"margin":[0,30,0,-43]},{"style":"invoiceLineItemsTable","table":{"headerRows":1,"widths":"$invoiceLineItemColumns","body":"$invoiceLineItems"},"layout":{"hLineWidth":"$notFirst:1","vLineWidth":"$none","hLineColor":"#e6e6e6","paddingLeft":"$amount:8","paddingRight":"$amount:8","paddingTop":"$amount:8","paddingBottom":"$amount:8"}},{"pageBreak":"after","columns":["$notesAndTerms",{"width":160,"style":"subtotals","table":{"widths":[60,60],"body":"$subtotals"},"layout":{"hLineWidth":"$none","vLineWidth":"$none","paddingLeft":"$amount:10","paddingRight":"$amount:10","paddingTop":"$amount:4","paddingBottom":"$amount:4"}}]},"Some text"]
i managed to do it with this !
thanks
for pple wanting to do it aswell
to create a new line do following
“textline”,
“textline2”,
" ", (skipping line)
Wanting to use zapier to pass across lines from a google sheet to form lines of an invoice.
am i right that i can only create a whole new invoice per line at present?
any plans to allow zaps to add lines to an invoice?
We support multiple line items using arrays
