I have an active white label plan however when i generate my invoice it still shows the invoice ninja logo on it. Is there something I need to do to remove it?
Are you creating new invoices or are you checking older invoices?
@david any thoughts to debug this?
The invoice is a draft I created before getting the white label license to apply properly.
I have just checked and created a new invoice and it does not have the logo on it.
Great! If you update the old invoice and re-save it I think it should correct itself.
Updating the old invoice and saving it did not seem to remove the logo - might be a bug that? I have deleted and recreated the invoice and it has no logo as expected
