I am in the process of setting up V5 of IN to ultimately migrate my v4 data. I am using docker.
I am currently stumped on how to set-up my payment gateway (Eway Rapid) in v5.
I can see there is an entry in the gateways table in the db and have changed the field visible from 0 to 1 in the hopes that would make it show when I try to set-up my payment gateway. But it still isn’t shown…
Clearly I am missing something and I’d appreciate some hint or help in getting my payment gateway set-up.
It should be available by default. When you go to Settings > Online Payments > Configure Gateways - do you see it from the drop down list as selectable?
So I go to Settings > Online Payments > Configure Gateways and I get an ‘empty’ screen. I then click on the + to add/configure a gateway and the list I get is fairly short and does NOT include any mention of eWay.
I am on version v5.3.55-C76 … docker image I am referencing is: invoiceninja/invoiceninja:5
Have hit other issues now and have decided instead of migrating from in4 in yunohost directly to in5 in docker, I’ll try a migration to in4 in docker first… hoping that is simpler.
Anyway, hitting an issue there as well… Will start a new thread about that if I can’t find anything after a search.
