Hi Guys
There seems to be an issue with logging in. Everytime I connect via web browser, I get Error 500 and have to first switch PHP 8.1 back to PHP 8.0 to see the login screen with the username/password etc. Then after I enter the credentials, I have to quickly switch back to PHP 8.1 as it won’t physically access on PHP 8.0.
Is there a work around this issue to just work properly on PHP8.1 without having to change it manually all the time?
This is my laravel log shows from yesterday:
[2022-09-10 10:46:34] production.ERROR: During inheritance of PDO: Uncaught ErrorException: Return type of Doctrine\DBAL\Driver\PDOConnection::exec($sql) should either be compatible with PDO::exec(string $statement): int|false, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/www/users/(commented out)/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:50
Stack trace:
#0 /usr/www/users/(commented out)/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php(22): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(8192, ‘Return type of …’, ‘/usr/www/users/…’, 50)
#1 /usr/www/users/(commented out)/vendor/composer/ClassLoader.php(480): include(‘/usr/www/users/…’)
#2 /usr/www/users/(commented out)/vendor/composer/ClassLoader.php(346): Composer\Autoload\includeFile(‘/usr/www/users/…’)
#3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‘Doctrine\DBAL\D…’)
#4 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(66): class_exists(‘Doctrine\DBAL\D…’)
#5 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(46): Illuminate\Database\Connectors\Connector->createPdoConnection(‘mysql:host=dedi…’, (commented out), ‘(commented out)…’, Array)
#6 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connectors/MySqlConnector.php(24): Illuminate\Database\Connectors\Connector->createConnection(‘mysql:host=dedi…’, Array, Array)
#7 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connectors/ConnectionFactory.php(184): Illuminate\Database\Connectors\MySqlConnector->connect(Array)
#8 [internal function]: Illuminate\Database\Connectors\ConnectionFactory->Illuminate\Database\Connectors{closure}()
#9 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(997): call_user_func(Object(Closure))
#10 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(1033): Illuminate\Database\Connection->getPdo()
#11 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(426): Illuminate\Database\Connection->getReadPdo()
#12 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(352): Illuminate\Database\Connection->getPdoForSelect(true)
#13 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->Illuminate\Database{closure}(‘select * from i…’, Array)
#14 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(652): Illuminate\Database\Connection->runQueryCallback(‘select * from i…’, Array, Object(Closure))
#15 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(360): Illuminate\Database\Connection->run(‘select * from i…’, Array, Object(Closure))
#16 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Schema/MySqlBuilder.php(44): Illuminate\Database\Connection->select(‘select * from i…’, Array)
#17 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\Database\Schema\MySqlBuilder->hasTable(‘accounts’)
#18 /usr/www/users/(commented out)/app/Exceptions/Handler.php(78): Illuminate\Support\Facades\Facade::__callStatic(‘hasTable’, Array)
#19 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(414): App\Exceptions\Handler->report(Object(ErrorException))
#20 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(112): Illuminate\Foundation\Http\Kernel->reportException(Object(ErrorException))
#21 /usr/www/users/(commented out)/public/index.php(57): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#22 {main} {“exception”:"[object] (Symfony\Component\ErrorHandler\Error\FatalError(code: 0): During inheritance of PDO: Uncaught ErrorException: Return type of Doctrine\DBAL\Driver\PDOConnection::exec($sql) should either be compatible with PDO::exec(string $statement): int|false, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /usr/www/users/(commented out)/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:50
Stack trace:
#3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‘Doctrine\\DBAL\\D…’)
#4 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connectors/Connector.php(66): class_exists(‘Doctrine\\DBAL\\D…’)
#8 [internal function]: Illuminate\Database\Connectors\ConnectionFactory->Illuminate\Database\Connectors\{closure}()
#13 /usr/www/users/(commented out)/vendor/laravel/framework/src/Illuminate/Database/Connection.php(685): Illuminate\Database\Connection->Illuminate\Database\{closure}(‘select * from i…’, Array)
#22 {main} at /usr/www/users/(commented out)/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOConnection.php:22)
#0 {main}
What I am running:
Invoice Ninja v5.5.20-C67
