markus
1
Hi there!
On V4, we used to send the Client Portal link for the quote or invoice to the customer, they’d click on it, review it, then approve/pay it.
On V5, it seems to be enforced that the customer needs to register an account first?
Can that be disabled? I’d like to retain the original capability.
xoo
Your impression is incorrect. I’m on v5, have disabled the client portal, and still can use $view_button in mail templates. Works as expected.
markus
3
My impression? Well, that’s a lovely way to put it.
But incidentally, deactivating the client portal did the trick. So, thanks, I guess?
david
4
Hi @markus
v5 works like v4, you can forward a magic link which will log the user in and display the invoice.
The magic link can be found in the UI under the contact tab of the invoice.
aka
5
Is there an API call to get this link ?
Thank you
david
6
The link is buried in the invitations array of the invoice ie:
curl -X GET 'http://ninja.test:8000/api/v1/invoices/1YQdJ2dOGp' \
-H "X-API-TOKEN:company-token-test" \
-H "X-Requested-With: XMLHttpRequest";
in the response will be a block like this:
"invitations": [
"id": "qM7e5Ba2vp",
"client_contact_id": "Wpmbk5ezJn",
"key": "qQxliE3c0DUZaoZOJvCUBFwfgYRbZeNw",
"link": "http:\/\/ninja.test:8000\/client\/invoice\/qQxliE3c0DUZaoZOJvCUBFwfgYRbZeNw",
"sent_date": "2023-04-11 22:53:13",
"viewed_date": "",
"opened_date": "",
"updated_at": 1681253593,
"archived_at": 0,
"created_at": 1681253593,
"email_status": "",
"email_error": ""
This invitation link is the dedicated link for the contact, this will take the user directly to the invoice.
