I’m trying to use the template for emails. The custom value for $amount will give the dollar amount with the dollar sign ($50.00). Is there a way to us or create a custom value for the amount without the $ sign?
I believe you can change $amount to $amount_raw to remove the formatting.
Yes! That did the trick, thanks for your help
