I have spent the last few hours trying to run both v4 and v5 using the docker image from docker hub. I either case, the container logs seem to do the db migration then post a status that php-fpm is ready to handle connection. However, when I try to access the web app, I continuously get a 503 error. Below is my config, can anyone provide some suggestions?
My docker-compose file is like the following.
version: '2'
services:
invoice-ninja-mariadb:
image: mariadb
command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW
volumes:
- /srv/dev-disk-by-label-mainpool/docker/volumes/invoice-ninja/mariadb/mysql:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=Obfuscated
- MYSQL_PASSWORD=Obfuscated
- MYSQL_DATABASE=ninja
- MYSQL_USER=ninja
invoice-ninja:
image: invoiceninja/invoiceninja:latest
volumes:
- /srv/dev-disk-by-label-mainpool/docker/volumes/invoice-ninja/invoice-ninja/public:/var/app/public
- /srv/dev-disk-by-label-mainpool/docker/volumes/invoice-ninja/invoice-ninja/storage:/var/app/storage
environment:
- APP_ENV=development
- APP_DEBUG=1
- APP_URL=https://billing.home.theorlandog.com/
- APP_KEY=Obfuscated
- APP_CIPHER=AES-256-CBC
- DB_TYPE=mysql
- DB_STRICT=false
- DB_HOST1=db
- DB_PORT1=3306
- DB_DATABASE1=ninja
- DB_USERNAME1=ninja
- DB_PASSWORD1=Obfuscated
- TRUSTED_PROXIES=10.0.0.0/8
ports:
- 127.0.0.1:9420:9000
depends_on:
- invoice-ninja-mariadb
links:
- invoice-ninja-mariadb:db
The logs of the container are below
Configuration cache cleared!,
Configuration cached successfully!,
Route cache cleared!,
Routes cached successfully!,
les cached successfully!,
Nothing to migrate.,
[15-Feb-2021 15:28:17] NOTICE: [pool www] 'user' directive is ignored when FPM is not running as root,
[15-Feb-2021 15:28:17] NOTICE: [pool www] 'group' directive is ignored when FPM is not running as root,
[15-Feb-2021 15:28:17] NOTICE: fpm is running, pid 78,
[15-Feb-2021 15:28:17] NOTICE: ready to handle connections,
Schedule worker started successfully.,
Execution #1 output:,
Running scheduled command: '/usr/local/bin/php' 'artisan' queue:work > '/dev/null' 2>&1,
Execution #2 output:,
Running scheduled command: '/usr/local/bin/php' 'artisan' queue:restart > '/dev/null' 2>&1,
Running scheduled command: App\Jobs\Util\SchedulerCheck,
Running scheduled command: Turbo124\Beacon\Jobs\BatchMetrics,
[2021-02-15 15:30:05][3] Processing: App\Jobs\Util\SchedulerCheck,
[2021-02-15 15:30:05][3] Processed: App\Jobs\Util\SchedulerCheck,
[2021-02-15 15:30:05][4] Processing: App\Jobs\Util\VersionCheck,
[2021-02-15 15:30:05][4] Processed: App\Jobs\Util\VersionCheck,
Execution #3 output:,
Execution #4 output:,
No scheduled commands are ready to run.,
Execution #5 output:,
Execution #6 output:,
Execution #7 output:,
[2021-02-15 15:35:04][5] Processing: App\Jobs\Util\SchedulerCheck,
[2021-02-15 15:35:04][5] Processed: App\Jobs\Util\SchedulerCheck,
[2021-02-15 15:35:04][6] Processing: App\Jobs\Util\VersionCheck,
[2021-02-15 15:35:04][6] Processed: App\Jobs\Util\VersionCheck,
Execution #8 output:,
Execution #9 output:,
Execution #10 output:,
Strangely enough, even if I exec into the container I can’t get a response from the php-fpm process.
~ $ netstat -tunlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.11:44095 0.0.0.0:* LISTEN -
tcp 0 0 :::9000 :::* LISTEN 78/php-fpm.conf)
udp 0 0 127.0.0.11:36469 0.0.0.0:* -
~ $ curl http://127.0.0.1:9000
curl: (56) Recv failure: Connection reset by peer
