I am having issue of “502 Bad Gateway”.
nginx file.
server {
listen 80 default_server;
server_name pay.mydomain.com;
client_max_body_size 100M;
gzip on;
gzip_types application/javascript application/x-javascript text/javascript text/plain appl ication/xml application/json;
gzip_proxied no-cache no-store private expired auth;
gzip_min_length 1000;
root /var/www/app/public/;
index index.php;
location / {
location = /robots.txt { access_log off; log_not_found off; }
location ~ \.php$ {
fastcgi_pass app:9000;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
docker-compose file
version: '3.7'
services:
server:
image: nginx
restart: always
env_file: ./env.env
volumes:
- ./ninja_volume/config/nginx/in-vhost.conf:/etc/nginx/conf.d/in-vhost.conf:ro
- ./ninja_volume/app/public:/var/www/app/public:ro
depends_on:
- app
networks:
- reverse-proxy
labels:
- traefik.enable=true
- traefik.http.routers.pay.rule=Host(`pay.mydomain.com`)
- traefik.http.routers.pay.entrypoints=websecure
- traefik.http.routers.pay.tls.certresolver=leresolver
app:
env_file: ./env.env
restart: always
volumes:
- ./ninja_volume/config/hosts:/etc/hosts:ro
- ./ninja_volume/app/public:/var/www/app/public:rw,delegated
- ./ninja_volume/app/storage:/var/www/app/storage:rw,delegated
networks:
- reverse-proxy
networks:
reverse-proxy:
external: true
Env file
# IN application vars
APP_URL=https://pay.mydomain.com
# docker run --rm -it invoiceninja/invoiceninja php artisan key:generate --show
APP_KEY=base64:xxxxxx
APP_DEBUG=false
REQUIRE_HTTPS=true
OPENEXCHANGE_APP_ID=xxxxxx
# DB connection
# mysql
DB_HOST=msql
DB_PORT=3306
DB_DATABASE=xxxxxx
DB_USERNAME=xxxxxx
DB_PASSWORD=xxxxxx
# Create initial user
IN_USER_EMAIL=xxxxxx
IN_PASSWORD=xxxxxx
# IN_USER_EMAIL=
# IN_PASSWORD=
# Mail options
MAIL_MAILER=log
MAIL_HOST=smtp.mailtrap.io
MAIL_PORT=2525
MAIL_USERNAME=null
MAIL_PASSWORD=null
MAIL_ENCRYPTION=null
MAIL_FROM_ADDRESS='[email protected]'
MAIL_FROM_NAME='xxxxxxr'
# MySQL
MYSQL_ROOT_PASSWORD=xxxxxx
MYSQL_USER=xxxxxx
MYSQL_PASSWORD=xxxxxx
MYSQL_DATABASE=xxxxxx
TRUSTED_PROXIES='*'
All happened after doing update with.
docker-compose down
docker-compose pull
docker-compose up
in app log
2021-07-01T12:12:12Z [ERROR] [Entrypoint]: Error connecting to DB
2021-07-01T12:12:12Z [INFO] [Entrypoint]: Initialising Invoice Ninja...
Configuration cache cleared!
Configuration cached successfully!
Route cache cleared!
Routes cached successfully!
Files cached successfully!
In Connection.php line 692:
SQLSTATE[HY000] [2002] No such file or directory (SQL: select * from inform
ation_schema.tables where table_schema = ninja and table_name = accounts an
d table_type = 'BASE TABLE')
In Exception.php line 18:
In PDOConnection.php line 39:
also tried - but not worked.
php artisan optimize
