I just received this error after updating to the latest version (v5.5.44-C102) and attempted to send a test invoice to myself.
Any idea what could be the cause of this @hillel ?
Thanks in advance.
Thanks in advance.
Which PDF generator are you using?
Hi Hillel and thanks for your reply.
We are using the default option of Phantomjs:
it has worked very well in the past so I am not sure why it is starting to troll me now…
Kind regards
Thanks! It should help to change to hosted_ninja
and then run php artisan optimize
cc @david
Ok, thanks
I’ll will try later today and test it and get back with a status whether it worked or not for me.
Kind regards
v5.5.45 should address this, if not, use hosted_ninja
“hosted_Ninja”
What is that parameter different from the “self_hosted” parameter in the .env file @david?
hosted_ninja refers to the PDF driver,
options are snappdf, hosted_ninja or phantom
selfhost release to the environment people are using, which will always be selfhost for the community
Oh you meant like that…
Now I get it.
Thanks David!
I seem to be having the same issue after upgrading to v5.5.45. No PDF generation when using snappdf
. Changing to PDF_GENERATOR
from snappdf
to hosted_ninja
seems to fix the issue after running php artisan optimize
. I’d rather use snappdf
. I believe the bug is still there. Can I give more information to reproduce? There is nothing in the apache error logs.
Are you able to run
./vendor/bin/snappdf download
If the system starts downloading snappdf, it means the binary wasn’t installed after the upgrade
I was able to run that command and it seems to have fixed then issue once I switch back to snappdf
in the .env
file for PDF_GENERATOR
$ ./vendor/bin/snappdf download
Starting download. Revision: 1079403
Download completed. Extracting the zip archive.
Archive extracted.
Completed! 1079403-Linux_x64 currently in use.
$ php artisan optimize
Looks great! Thanks!
