v5.3.0 working perfectly under Debian/Nginx. As soon as I run the upgrade from the web, it runs and works fine EXCEPT if I go to change any settings, as soon as I save, I get a 500 Server Error. I have checked permissions and can’t find any issues. The only way I can fix it is to restore the vm from a backup.
Are there any details about the error in storage/logs/
I checked. Nothing. Nothing in the nginx logs either.
I think this could be the AP.
@david what is the AP?
The Admin Portal UI
Tried to upgrade from 5.3.0 to 5.3.8. Same issue. Only occurs when updating settings. Invoices, Quotes, Clients all work fine.
I think we all have same error with 5.3.8
small snippet of the error in debug mode
500: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘report_include_drafts’ in ‘field list’ (SQL: update companies set convert_products = 0, fill_products = 1, update_products = 1, show_product_details = 0, client_can_register = 1, custom_surcharge_taxes1 = 0, custom_surcharge_taxes2 = 0, custom_surcharge_taxes3 = 0, custom_surcharge_taxes4 = 0, enable_product_cost = 0, enable_product_quantity = 1, default_quantity = 1, settings = {“auto_archive_invoice”:false,“lock_invoices”:“off”,“enable_client_portal_tasks”:true,“show_all_tasks_client_portal”:“invoiced”,“enable_client_portal_password”:true,“enable_client_portal”:true,“enable_client_portal_dashboard”:true,“signature_on_pdf”:true,“document_email_attachment”:true,“portal_design_id”:“1”,“timezone_id”:“14”,“date_format_id”:“5”,“military_time”:false,“language_id”:“1”,“show_currency_code”:false,“company_gateway_ids”:"",“currency_id”:“1”,“custom_value1”:"",“custom_value2”:"",“custom_value3”:"",“custom_value4”:"",“default_task_rate”:7,“payment_terms”:"",“send_reminders”:true,“custom_message_dashboard”:"",“custom_message_unpaid_invoice”:"",“custom_message_paid_invoice”:"",“custom_message_unapproved_quote”:"",“auto_archive_quote”:true,“auto_convert_quote”:true,“auto_email_invoice”:true,“entity_send_time”:0,“inclusive_taxes”:false,“quote_footer”:"",“translations”:[],“counter_number_applied”:“when_saved”,“quote_number_applied”:“when_saved”,“invoice_number_pattern”:“INV{$year}-{$counter}”,“invoice_number_counter”:11,“recurring_invoice_number_pattern”:“INV{$year}-{client_number}-{$counter}”,“recurring_invoice_number_counter”:1,“quote_number_pattern”:“QUOTE-{$date:Y}-{$counter}”,“quote_number_counter”:5,“client_number_pattern”:“IDC-{$counter}”,“client_number_counter”:7,“credit_number_pattern”:“CREDIT-{$client_number}-{$date:m-d-Yt}”,“credit_number_counter”:1,“task_number_pattern”:"",“task_number_counter”:1,“expense_number_pattern”:“EXP-{$year}-{$counter}”,“expense_number_counter”:2,“vendor_number_pattern”:“VEND-{$counter}”,“vendor_number_counter”:2,“ticket_number_pattern”:"",“ticket_number_counter”:1,“payment_number_pattern”:“PAYMENT-{client_number}-{$counter}”,“payment_number_counter”:6,“project_number_pattern”:"",“project_number_counter”:1,“shared_invoice_quote_counter”:true,“shared_invoice_credit_counter”:true,“recurring_number_prefix”:“R”,“reset_counter_frequency_id”:“0”,"reset_counter_date
It may help to load /update in the browser or if not to run php artisan migrate from the CLI.
cc @david
/update did not work, but php artisan migrate seems to have fixed the issue. I will continue to test. Thanks!
I just moved my installation to a different server after some problems during the update process.
Not sure if it’s the same error (related to the topic) but whenever I try to save some settings I get the following error.
500: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘invoice_task_lock’ in ‘field list’ (SQL: update
companiessetconvert_products= 0,fill_products= 1,update_products= 1,show_product_details= 0,client_can_register= 0,custom_surcharge_taxes1= 0,custom_surcharge_taxes2= 0,custom_surcharge_taxes3= 0,custom_surcharge_taxes4= 0,enable_product_cost= 0,enable_product_quantity= 1,default_quantity= 1,portal_domain= https://tester.DOMAIN`settings` = {“auto_archive_invoice”:true,“qr_iban”:“”,“besr_id”:“”,“lock_invoices”:“off”,“enable_client_portal_tasks”:false,“show_all_tasks_client_portal”:“invoiced”,“enable_client_portal_password”:false,“enable_client_portal”:true,“enable_client_portal_dashboard”:true,“signature_on_pdf”:false,“document_email_attachment”:true,“portal_design_id”:“1”,“timezone_id”:“36”,“date_format_id”:“11”,“military_time”:true,“language_id”:“3”,“show_currency_code”:false,“company_gateway_ids”:“”,“currency_id”:“3”,“custom_value1”:“”,“custom_value2”:“”,“custom_value3”:“”,“custom_value4”:“”,“default_task_rate”:65,“payment_terms”:“7”,“send_reminders”:true,“custom_message_dashboard”:“”,“custom_message_unpaid_invoice”:“”,“custom_message_paid_invoice”:“”,“custom_message_unapproved_quote”:“”,“auto_archive_quote”:false,“auto_convert_quote”:true,“auto_email_invoice”:true,“entity_send_time”:6,“inclusive_taxes”:false,“quote_footer”:“”,“translations”:,“counter_number_applied”:“when_saved”,“quote_number_applied”:“when_saved”,“invoice_number_pattern”:“{$date:Ymd}-{$counter}”,“invoice_number_counter”:186,“recurring_invoice_number_pattern”:“”,“recurring_invoice_number_counter”:1,“quote_number_pattern”:“”,“quote_number_counter”:1,“client_number_pattern”:“”,“client_number_counter”:15,“credit_number_pattern”:“”,“credit_number_counter”:0,“task_number_pattern”:“”,“task_number_counter”:15,“expense_number_pattern”:“”,“expense_number_counter”:1,“recurring_expense_number_pattern”:“”,“recurring_expense_number_counter”:1,“recurring_quote_number_pattern”:“”,“recurring_quote_number_counter”:1,“vendor_number_pattern”:“”,“vendor_number_counter”:1,“ticket_number_pattern”:“”,“ticket_number_counter”:1,“payment_number_pattern”:“”,“payment_number_counter”:20,“project_number_pattern”:“”,“project_number_counter”:2,“purchase_order_number_pattern”:“”,“purchase_order_number_counter”:1,“shared_invoice_quote_counter”:true,“shared_invoice_credit_counter”:false,“recurring_number_prefix”:“R”,“reset_counter_frequency_id”:“0”,“reset_counter_date”:
I did the /update?secret= and php artisan migrate but nothing changed.
user@tattoine:/var/www/invoiceninja$ sudo php artisan migrate
APPLICATION IN PRODUCTION.
Do you really wish to run this command? (yes/no) [no]
❯ yes
INFO Nothing to migrate
