Original Version: 5.5.21
Attempted Upgrade Version: 5.5.37
Using the built in upgrade mechanism was not working at all. Unfortunately I don’t remember the error but I believe it was related to the change to PHP 8.1. I am running PHP 8.1.11.
When I login, if I put in the wrong 2FA code, it will prompt with that error. When I put in the correct 2FA code, I get a 500: Server Error, and see the following in the logs:
[2022-11-05 17:40:02] production.ERROR: The “–once*” option does not exist. {“exception”:"[object] (Symfony\Component\Console\Exception\RuntimeException(code: 0): The "–once*" option does not exist. at /home//my.domain.com/vendor/symfony/console/Input/ArgvInput.php:220)
#0 /home//my.domain.com/vendor/symfony/console/Input/ArgvInput.php(149): Symfony\Component\Console\Input\ArgvInput->addLongOption()
#1 /home//my.domain.com/vendor/symfony/console/Input/ArgvInput.php(82): Symfony\Component\Console\Input\ArgvInput->parseLongOption()
#2 /home//my.domain.com/vendor/symfony/console/Input/ArgvInput.php(71): Symfony\Component\Console\Input\ArgvInput->parseToken()
#3 /home//my.domain.com/vendor/symfony/console/Input/Input.php(55): Symfony\Component\Console\Input\ArgvInput->parse()
#4 /home//my.domain.com/vendor/symfony/console/Command/Command.php(267): Symfony\Component\Console\Input\Input->bind()
#5 /home//my.domain.com/vendor/laravel/framework/src/Illuminate/Console/Command.php(148): Symfony\Component\Console\Command\Command->run()
#6 /home//my.domain.com/vendor/symfony/console/Application.php(1014): Illuminate\Console\Command->run()
#7 /home//my.domain.com/vendor/symfony/console/Application.php(301): Symfony\Component\Console\Application->doRunCommand()
#8 /home//my.domain.com/vendor/symfony/console/Application.php(171): Symfony\Component\Console\Application->doRun()
#9 /home//my.domain.com/vendor/laravel/framework/src/Illuminate/Console/Application.php(102): Symfony\Component\Console\Application->run()
#10 /home//my.domain.com/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(155): Illuminate\Console\Application->run()
#11 /home/*******/my.domain.com/artisan(37): Illuminate\Foundation\Console\Kernel->handle()
#12 {main}
Any suggestions on where to look/what to try?
Chris
