500 error when saving new generated number for Invoices v5.10.8
Hello Everyone,
I recently updated using Softaculous from version 5.8.38 to 5.10.8, when trying to save a new Generated Number (Generated Numbers/invoices/Number Counter) I get a 500 error as shown in screenshot. I have downgraded back to 5.8.38 as this version seems to work without issues.
Regards
Hello, i have the same error too (500 Server Error) updating from 5.8.46 to 5.10.8 v5 Selfhosted using Softaculous too, had to downgrade to 5.8.46 can’t change Generated Number “Invoice”
thanks in advance
ps: The strange thing is that I have another installation of the same v5 self hosted with softaculous only that this one was in 5.9.4 and I upgraded to 5.10.8 and in this instance it does let me change the generated numbers (invoice)
Hello, Seems the issue is only caused when using the Desktop and mobile app. When I tried this from web app, it worked fine. I was using console to check the error, but since it’s not the web app was unable to check the issue
Regards
Please check storage/logs for details about the error
Hello, log file:
[2024-07-15 09:40:40] production.ERROR: Undefined array key “Invoice” {“userId”:1,“exception”:"[object] (ErrorException(code: 0): Undefined array key "Invoice" at /Path removed for securty/httpdocs/app/Http/ValidationRules/EInvoice/ValidCompanyScheme.php:39)
#0 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(256): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
#1 /Path removed for securty/httpdocs/app/Http/ValidationRules/EInvoice/ValidCompanyScheme.php(39): Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
#2 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/InvokableValidationRule.php(102): App\Http\ValidationRules\EInvoice\ValidCompanyScheme->validate()
#3 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(867): Illuminate\Validation\InvokableValidationRule->passes()
#4 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(656): Illuminate\Validation\Validator->validateUsingCustomRule()
#5 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(459): Illuminate\Validation\Validator->validateAttribute()
#6 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/Validator.php(494): Illuminate\Validation\Validator->passes()
#7 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Validation/ValidatesWhenResolvedTrait.php(31): Illuminate\Validation\Validator->fails()
#8 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Providers/FormRequestServiceProvider.php(30): Illuminate\Foundation\Http\FormRequest->validateResolved()
#9 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Container/Container.php(1294): Illuminate\Foundation\Providers\FormRequestServiceProvider->Illuminate\Foundation\Providers\{closure}()
#10 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Container/Container.php(1258): Illuminate\Container\Container->fireCallbackArray()
#11 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Container/Container.php(1244): Illuminate\Container\Container->fireAfterResolvingCallbacks()
#12 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Container/Container.php(805): Illuminate\Container\Container->fireResolvingCallbacks()
#13 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1041): Illuminate\Container\Container->resolve()
#14 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Container/Container.php(723): Illuminate\Foundation\Application->resolve()
#15 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(1026): Illuminate\Container\Container->make()
#16 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(85): Illuminate\Foundation\Application->make()
#17 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(50): Illuminate\Routing\ControllerDispatcher->transformDependency()
#18 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/ResolvesRouteDependencies.php(29): Illuminate\Routing\ControllerDispatcher->resolveMethodDependencies()
#19 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(59): Illuminate\Routing\ControllerDispatcher->resolveClassMethodDependencies()
#20 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(40): Illuminate\Routing\ControllerDispatcher->resolveParameters()
#21 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(21): Illuminate\Routing\ControllerDispatcher->dispatch()
#22 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingRoutingDispatcher.php(17): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->Sentry\Laravel\Tracing\Routing\{closure}()
#23 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Routing/TracingControllerDispatcherTracing.php(20): Sentry\Laravel\Tracing\Routing\TracingRoutingDispatcher->wrapRouteDispatch()
#24 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Sentry\Laravel\Tracing\Routing\TracingControllerDispatcherTracing->dispatch()
#25 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Route.php(206): Illuminate\Routing\Route->runController()
#26 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Router.php(806): Illuminate\Routing\Route->run()
#27 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Routing\Router->Illuminate\Routing\{closure}()
#28 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(124): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(89): Illuminate\Routing\Middleware\ThrottleRequests->handleRequestUsingNamedLimiter()
#30 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\ThrottleRequests->handle()
#31 /Path removed for securty/httpdocs/app/Http/Middleware/QueryLogging.php(39): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\QueryLogging->handle()
#33 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#34 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Routing\Middleware\SubstituteBindings->handle()
#35 /Path removed for securty/httpdocs/app/Http/Middleware/Locale.php(95): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#36 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Locale->handle()
#37 /Path removed for securty/httpdocs/app/Http/Middleware/TokenAuth.php(102): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#38 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\TokenAuth->handle()
#39 /Path removed for securty/httpdocs/app/Http/Middleware/SetDb.php(40): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#40 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\SetDb->handle()
#41 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#42 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Router.php(805): Illuminate\Pipeline\Pipeline->then()
#43 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Router.php(784): Illuminate\Routing\Router->runRouteWithinStack()
#44 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Router.php(748): Illuminate\Routing\Router->runRoute()
#45 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Routing/Router.php(737): Illuminate\Routing\Router->dispatchToRoute()
#46 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\Routing\Router->dispatch()
#47 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(144): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#48 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/FlushEventsMiddleware.php(13): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#49 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\FlushEventsMiddleware->handle()
#50 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
#52 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#53 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Http\SetRequestMiddleware->handle()
#54 /Path removed for securty/httpdocs/vendor/livewire/livewire/src/Features/SupportDisablingBackButtonCache/DisableBackButtonCacheMiddleware.php(19): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#55 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Livewire\Features\SupportDisablingBackButtonCache\DisableBackButtonCacheMiddleware->handle()
#56 /Path removed for securty/httpdocs/app/Http/Middleware/Cors.php(24): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): App\Http\Middleware\Cors->handle()
#58 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#59 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\TrustProxies->handle()
#60 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#61 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#62 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
#63 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#64 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(51): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#65 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
#66 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Http/Middleware/ValidatePostSize.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#67 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Http\Middleware\ValidatePostSize->handle()
#68 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(110): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#69 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
#70 /Path removed for securty/httpdocs/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(97): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#71 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(183): Sentry\Laravel\Tracing\Middleware->handle()
#72 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(119): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#73 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\Pipeline\Pipeline->then()
#74 /Path removed for securty/httpdocs/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#75 /Path removed for securty/httpdocs/public/index.php(56): Illuminate\Foundation\Http\Kernel->handle()
#76 {main}
Regards.
@david do you have any ideas?
Hello Hillel, I wanted to inform you that I tried again the upgrade with this latest version (5.10.10) and now it allows me to change when saving a new Generated Number, it no longer shows the error 500
Installed version 5.10.11 from Softaculous, generated numbers issue confirmed fixed.
Thanks)
