500 Error / PDF Generation
According to env. We have the ninja_hosted in the PDF generation. Nothing was changed except for updates. Unfortunately it no longer generates PDFs for us.
What could be the reason? Everything has gone smoothly so far!
Is there a scheme to check or what you need to know so I can provide you with the information?
Where can I find the log files exactly? We use Cloudron.io with InvoiceNinja! I’m really confused right now. xD
There is a folder called storage/logs which should contain a log file
