I get a 500 error when accessing the vendor portal from a purchase order. I had a similar issue several months back with details here. I can again open the vendor portal from the vendor tab, however, any open POs are not visible in the portal.
Below is the error exception from the debug of the vendor portal.
ErrorException:
Undefined property: stdClass::$purchase_order_details
at /usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php:206
at Illuminate\Foundation\Bootstrap\HandleExceptions->handleError()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php:254)
at Illuminate\Foundation\Bootstrap\HandleExceptions->Illuminate\Foundation\Bootstrap\{closure}()
(/usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php:206)
at App\Http\Livewire\PdfSlot->getEntityDetails()
(/usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php:147)
at App\Http\Livewire\PdfSlot->render()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36)
at Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php:41)
at Illuminate\Container\Util::unwrapIfClosure()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93)
at Illuminate\Container\BoundMethod::callBoundMethod()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:37)
at Illuminate\Container\BoundMethod::call()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php:662)
at Illuminate\Container\Container->call()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/Component.php:173)
at Livewire\Component->renderToView()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/LifecycleManager.php:131)
at Livewire\LifecycleManager->renderToView()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/LivewireManager.php:131)
at Livewire\LivewireManager->mount()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:353)
at Illuminate\Support\Facades\Facade::__callStatic()
(/usr/share/nginx/invoiceninja/storage/framework/views/11092ce4bbbde6d577b4fb63940b8825.php:52)
at require('/usr/share/nginx/invoiceninja/storage/framework/views/11092ce4bbbde6d577b4fb63940b8825.php')
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php:124)
at Illuminate\Filesystem\Filesystem::Illuminate\Filesystem\{closure}()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php:125)
at Illuminate\Filesystem\Filesystem->getRequire()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php:58)
at Illuminate\View\Engines\PhpEngine->evaluatePath()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/ComponentConcerns/RendersLivewireComponents.php:69)
at Livewire\LivewireViewCompilerEngine->evaluatePath()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php:72)
at Illuminate\View\Engines\CompilerEngine->get()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/ComponentConcerns/RendersLivewireComponents.php:35)
at Livewire\LivewireViewCompilerEngine->get()
(/usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/ViewEngineDecorator.php:34)
at Sentry\Laravel\Tracing\ViewEngineDecorator->get()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php:195)
at Illuminate\View\View->getContents()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php:178)
at Illuminate\View\View->renderContents()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php:147)
at Illuminate\View\View->render()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Response.php:69)
at Illuminate\Http\Response->setContent()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Response.php:35)
at Illuminate\Http\Response->__construct()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:911)
at Illuminate\Routing\Router::toResponse()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:878)
at Illuminate\Routing\Router->prepareResponse()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:799)
at Illuminate\Routing\Router->Illuminate\Routing\{closure}()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:141)
at Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
(/usr/share/nginx/invoiceninja/app/Http/Middleware/VendorLocale.php:49)
at App\Http\Middleware\VendorLocale->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:180)
(/usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php:40)
at App\Http\Middleware\QueryLogging->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php:50)
at Illuminate\Routing\Middleware\SubstituteBindings->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php:57)
at Illuminate\Auth\Middleware\Authenticate->handle()
(/usr/share/nginx/invoiceninja/app/Http/Middleware/SetDomainNameDb.php:39)
at App\Http\Middleware\SetDomainNameDb->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php:78)
at Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php:49)
at Illuminate\View\Middleware\ShareErrorsFromSession->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php:37)
at Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
(/usr/share/nginx/invoiceninja/app/Http/Middleware/SessionDomains.php:30)
at App\Http\Middleware\SessionDomains->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:121)
at Illuminate\Session\Middleware\StartSession->handleStatefulRequest()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php:64)
at Illuminate\Session\Middleware\StartSession->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php:67)
at Illuminate\Cookie\Middleware\EncryptCookies->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php:116)
at Illuminate\Pipeline\Pipeline->then()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:800)
at Illuminate\Routing\Router->runRouteWithinStack()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:777)
at Illuminate\Routing\Router->runRoute()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:741)
at Illuminate\Routing\Router->dispatchToRoute()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php:730)
at Illuminate\Routing\Router->dispatch()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:200)
at Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
(/usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php:45)
at Sentry\Laravel\Http\SetRequestIpMiddleware->handle()
(/usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php:31)
at Sentry\Laravel\Http\SetRequestMiddleware->handle()
(/usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php:19)
at Livewire\DisableBrowserCache->handle()
(/usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php:24)
at App\Http\Middleware\Cors->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php:39)
at Illuminate\Http\Middleware\TrustProxies->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php:21)
at Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php:31)
at Illuminate\Foundation\Http\Middleware\ConvertEmptyStringsToNull->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php:40)
at Illuminate\Foundation\Http\Middleware\TrimStrings->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php:27)
at Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php:89)
at Illuminate\Foundation\Http\Middleware\PreventRequestsDuringMaintenance->handle()
(/usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php:87)
at Sentry\Laravel\Tracing\Middleware->handle()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:175)
at Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
(/usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php:144)
at Illuminate\Foundation\Http\Kernel->handle()
(/usr/share/nginx/invoiceninja/public/index.php:57)
This is the latest entry from the laravel.log
file:
[previous exception] [object] (ErrorException(code: 0): Undefined property: stdClass::$purchase_order_details at /usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php:206)
#0 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/HandleExceptions.php(254): Illuminate\\Foundation\\Bootstrap\\HandleExceptions->handleError()
#1 /usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php(206): Illuminate\\Foundation\\Bootstrap\\HandleExceptions->Illuminate\\Foundation\\Bootstrap\\{closure}()
#2 /usr/share/nginx/invoiceninja/app/Http/Livewire/PdfSlot.php(147): App\\Http\\Livewire\\PdfSlot->getEntityDetails()
#3 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): App\\Http\\Livewire\\PdfSlot->render()
#4 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#5 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#6 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#7 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Container/Container.php(662): Illuminate\\Container\\BoundMethod::call()
#8 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/Component.php(173): Illuminate\\Container\\Container->call()
#9 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/LifecycleManager.php(131): Livewire\\Component->renderToView()
#10 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/LivewireManager.php(131): Livewire\\LifecycleManager->renderToView()
#11 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(353): Livewire\\LivewireManager->mount()
#12 /usr/share/nginx/invoiceninja/storage/framework/views/11092ce4bbbde6d577b4fb63940b8825.php(52): Illuminate\\Support\\Facades\\Facade::__callStatic()
#13 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(124): require('...')
#14 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Filesystem/Filesystem.php(125): Illuminate\\Filesystem\\Filesystem::Illuminate\\Filesystem\\{closure}()
#15 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Engines/PhpEngine.php(58): Illuminate\\Filesystem\\Filesystem->getRequire()
#16 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/ComponentConcerns/RendersLivewireComponents.php(69): Illuminate\\View\\Engines\\PhpEngine->evaluatePath()
#17 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Engines/CompilerEngine.php(72): Livewire\\LivewireViewCompilerEngine->evaluatePath()
#18 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/ComponentConcerns/RendersLivewireComponents.php(35): Illuminate\\View\\Engines\\CompilerEngine->get()
#19 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/ViewEngineDecorator.php(34): Livewire\\LivewireViewCompilerEngine->get()
#20 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php(195): Sentry\\Laravel\\Tracing\\ViewEngineDecorator->get()
#21 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php(178): Illuminate\\View\\View->getContents()
#22 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/View.php(147): Illuminate\\View\\View->renderContents()
#23 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Response.php(69): Illuminate\\View\\View->render()
#24 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Response.php(35): Illuminate\\Http\\Response->setContent()
#25 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(911): Illuminate\\Http\\Response->__construct()
#26 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(878): Illuminate\\Routing\\Router::toResponse()
#27 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\\Routing\\Router->prepareResponse()
#28 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
#29 /usr/share/nginx/invoiceninja/app/Http/Middleware/VendorLocale.php(49): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#30 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\VendorLocale->handle()
#31 /usr/share/nginx/invoiceninja/app/Http/Middleware/QueryLogging.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#32 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\QueryLogging->handle()
#33 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#34 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#35 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(57): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#36 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Auth\\Middleware\\Authenticate->handle()
#37 /usr/share/nginx/invoiceninja/app/Http/Middleware/SetDomainNameDb.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#38 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\SetDomainNameDb->handle()
#39 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#40 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\VerifyCsrfToken->handle()
#41 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#42 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\View\\Middleware\\ShareErrorsFromSession->handle()
#43 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#44 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Cookie\\Middleware\\AddQueuedCookiesToResponse->handle()
#45 /usr/share/nginx/invoiceninja/app/Http/Middleware/SessionDomains.php(30): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#46 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\SessionDomains->handle()
#47 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(121): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#48 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(64): Illuminate\\Session\\Middleware\\StartSession->handleStatefulRequest()
#49 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Session\\Middleware\\StartSession->handle()
#50 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#51 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Cookie\\Middleware\\EncryptCookies->handle()
#52 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#53 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(800): Illuminate\\Pipeline\\Pipeline->then()
#54 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(777): Illuminate\\Routing\\Router->runRouteWithinStack()
#55 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(741): Illuminate\\Routing\\Router->runRoute()
#56 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Routing/Router.php(730): Illuminate\\Routing\\Router->dispatchToRoute()
#57 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(200): Illuminate\\Routing\\Router->dispatch()
#58 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
#59 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestIpMiddleware.php(45): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#60 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\\Laravel\\Http\\SetRequestIpMiddleware->handle()
#61 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Http/SetRequestMiddleware.php(31): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#62 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\\Laravel\\Http\\SetRequestMiddleware->handle()
#63 /usr/share/nginx/invoiceninja/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#64 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\\DisableBrowserCache->handle()
#65 /usr/share/nginx/invoiceninja/app/Http/Middleware/Cors.php(24): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#66 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Cors->handle()
#67 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#68 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Http\\Middleware\\TrustProxies->handle()
#69 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#70 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#71 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
#72 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#73 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#74 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#75 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#76 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
#77 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(89): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#78 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
#79 /usr/share/nginx/invoiceninja/vendor/sentry/sentry-laravel/src/Sentry/Laravel/Tracing/Middleware.php(87): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#80 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Sentry\\Laravel\\Tracing\\Middleware->handle()
#81 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#82 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(175): Illuminate\\Pipeline\\Pipeline->then()
#83 /usr/share/nginx/invoiceninja/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(144): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#84 /usr/share/nginx/invoiceninja/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
#85 {main}
I’m running v5.7.11 and this started prior to upgrading to x.11
Thanks for your help, let me know if I can provide any additional information.
